RX 330 Recall - Headlight Moisture Issue
Old 08-15-11, 09:23 AM
mandyfig
mandyfig's Avatar
Like this repair. This is basically what I sealed. Knowing what I know now, tearing the headlamp apart was not necessary.
Try this 1st, if it does not work, more sealing required.
Attached Thumbnails RX 330 Recall - Headlight Moisture Issue-sealed_headlamp.jpg
Old 08-15-11, 09:27 AM
mandyfig
mandyfig's Avatar
Another member did this, but mine was basically the same area.
What is happening is that rain (or any source of water, like car wash) will seep into casing through small cracks berween the casing.
Our headlamps are designed to allow evaporation of water vapor. But saturation of water is too much. hence it takes days, weeks for the water condensation to disappear.
Old 08-18-11, 11:35 PM
RX330inFL
RX330inFL's Avatar
One of the things I have contemplated was to replace the headlights. For now, I am going to patch them with Permatex as discussed, however, when I inspected the lenses they seemed a bit cloudy on the inside of the lens. Probably from moisture over the years.
So, while watching the football games this evening I took a look on eBay. Found these:
http://cgi.ebay.com/ebaymotors/Lexus...ht_1588wt_1146
Anyone else replace their halogen lenses up front who can suggest a vendor to look at? Quality? Price? Are the third-party ones any good?
Was going to take the front bumper off to be repainted anyway. This can be done at the same time.
Input is appreciated.
Old 08-30-11, 08:44 PM
jednav
jednav's Avatar
Had the same problem with both headlamps. My extended warranty was expired. Dealer wanted about $5000.00 for parts and labor. Called corporate office in Ontario. Both headlamps replaced for FREE of charge.
Old 08-30-11, 10:46 PM
Carver
Carver's Avatar
Those look as good as any, good seller too. You might give them a good seal before you install them.
Old 08-31-11, 08:32 AM
Rainbird
Rainbird's Avatar
There is a class action lawsuit against Lexus regarding the headlight moisture issue. Who knows how that will turn out or how long it will take:
http://www.topclassactions.com/lawsu...t-class-action
Old 08-31-11, 09:49 AM
RX330inFL
RX330inFL's Avatar
That is usually great for the lawyers while those affected by the defect are left with pennies on the dollar for their troubles. Am going to guess the best we will get is a credit towards a future purchase (sales or service).
Old 08-31-11, 01:03 PM
Rainbird
Rainbird's Avatar
Sad, but True!
Old 09-16-11, 03:42 PM
RX330inFL
RX330inFL's Avatar
http://cgi.ebay.com/ebaymotors/Lexus...ht_1588wt_1146.
Noticed that the price on these dropped to $230 for the pair. So, went ahead and purchased. When I get to do the install is another matter. May be a bit.
Old 09-16-11, 06:46 PM
mandyfig
mandyfig's Avatar
Not bad at all
Old 09-28-11, 09:02 AM
MiralliMax
MiralliMax's Avatar
Anybody with rx headlight condensation moisture water issue should file a complain http://www-odi.nhtsa.dot.gov/complaints/ Only that way we can have lexus repair their faulty headlights
Old 10-03-11, 07:08 AM
soda7o
soda7o's Avatar
sealed my headlight over the weekend
so far so good no moisture since sealing
in the process replaced my ballast as it was fried due to the moisture from the headlight getting to the ballast
adlewis
03-28-14 01:53 PM
kimberlyd2
12-07-13 01:54 AM
derekchiou
09-17-11 08:32 AM
BAD RIDES
01-24-11 08:09 PM
Georgie
02-02-10 02:18 PM
Quick Reply: RX 330 Recall - Headlight Moisture Issue
