Changing Fog Light Bulbs???? HELP
Hi - I am a new (used) Rx 350 owner and need to change the fog light bulbs. The owners manual says to access through the 2 holes directly beneath the fog lights but there is too much stuff in the way and i cannot get my hand in.
Ant thoughts are appreciated. Do i have to access by removing the fender liner??
Thanks
2009 RX 350
Thanks
2009 RX 350
For the passenger side, I had to remove the washer fluid hose and I was able to reach down to change the bulb.
For the driver side, I had to loosen the battery hold-down bracket, move the battery an inch or so, and I was then able to reach down and replace the bulb.
Removing the fender liner is not really a bad deal. Very straightforward. I did a side repeater DIY and a HL condensation repair and it shows how to remove the fender liner.
Yes thanks for all the help. I removed 2 screws and pulled out the fender liner. Piece of cake to 15 minutes to d both sides. Thanks again to this great forum
Bass2zion (01-13-20)
ReyRey305
04-08-08 05:38 AM
