gas tank cover
Old 05-10-15, 06:38 AM
thomas1
thomas1's Avatar
The best way is to look under the car and you will see a few edges that are extremely close to the underbody. On mine I was able to softly hit the panel and hear the points of contact. good luck
Old 05-10-15, 08:29 AM
Rainbird
Rainbird's Avatar
Originally Posted by msgntsu
Sorry for the additional questions, but can someone give me a better description of the 3M tape or the foam tape that is needed to fix the problem. I went by Autozone, but I couldn't locate what I would think would be needed to fix it. Also, any do I put the tape/foam around all the edges, or in a particular spot? BTW... I thought I would just by a new one from Lexus, but it's unbelievable what they want for that piece of metal...
Thanks again or the assistance...
The Home Depot sells heavy duty foam tape. It is mostly used for weather stripping, but it should work well for this.
Old 05-11-15, 09:44 AM
mandyfig
mandyfig's Avatar
Trying to figure out the original problem…someone can explain? I need to learn too.
Old 05-11-15, 10:15 AM
Rainbird
Rainbird's Avatar
Look at the TSB I posted in reply #11. Lexus of course wants to replace the entire fuel tank protector ($$$). All that is needed is to replace the deteriorated foam tape between the protector and the car body.
Old 05-30-15, 05:17 PM
msgntsu
msgntsu's Avatar
I decided to do this today and I foind it extremely difficult to get under the car. Did you put the car up on racks, or did you remove the cover and add tape while it was on the car?
Thanks,
Mike
Old 06-13-15, 07:01 AM
msgntsu
msgntsu's Avatar
Any responses
Old 06-15-15, 09:46 AM
mandyfig
mandyfig's Avatar
You have to lift the car on stands, that's the safe way anyway. Or use ramps, however also use chocks. Safety 1st.
Old 06-15-15, 02:53 PM
tadclark
tadclark's Avatar
Default Use foam pipe insulation
five years ago I simply bought a one foot piece of foam pipe insulation that is already pre slit. Cut it to fit around the side facing the front on the plastic cover. Secure with some duct tape. Problem solved. No noise since then. Btw no need to jack up. Just lay on the ground and reach under the car to apply it. Ten minute job.
Chavez562
04-05-17 05:59 AM
silvaIS
10-04-14 06:52 AM
Infin1ty
05-05-08 01:21 PM
DaveJ
RX - 1st Gen (1999-2003)
27
12-19-06 08:54 PM
CLCC
05-14-05 07:40 AM
Quick Reply: gas tank cover
