24 hour gas stations between Toronto and Key Largo
Hello All,
I'm planning a June trip to dive with Conch Republic Divers, in Florida.
My question to all members is about 24 hour gas stations. I've attached the route that I'll be taking. Typically I leave Toronto at 4am so getting gas is not a problem. However for this trip I will be Toronto at 10pm and really don't want to run out of gas. My major area of concern is through VA and WV, I know the other states have 24 hour gas stations. It would be rather lonely running out of gas somewhere in the mountains without cell signal
If I may get any gas stations along this route that will be open during the wee hours. Hopefully someone has these addresses saved on their GPS.
Thanks in advance,
Chris
Here is the Route from the Peace Bridge:
13. Turn SLIGHT RIGHT. 0.2 mi Map | Avoid
14. Merge onto I-190 S/NEW YORK STATE THRUWAY toward DOWNTOWN BUFFALO/I-90/NEW YORK STATE THRUWAY. 6.7 mi Map | Avoid
15. Merge onto I-90 W via EXIT 54-61 toward ERIE (Portions toll) (Crossing into PENNSYLVANIA). 94.4 mi Map | Avoid
16. Merge onto I-79 S via EXIT 22A toward PITTSBURGH. 144.0 mi Map | Avoid
17. Merge onto I-79 S via EXIT 21 toward MORGANTOWN (Crossing into WEST VIRGINIA). 136.4 mi Map | Avoid
18. Merge onto US-19 S via EXIT 57 toward SUMMERSVILLE/BECKLEY. 67.5 mi Map | Avoid
19. US-19 S becomes US-19 ALT S (Portions toll). 1.9 mi Map | Avoid
20. Merge onto I-64 E/I-77 S (Portions toll). 6.9 mi Map | Avoid
21. Keep RIGHT to take I-77 S via EXIT 40 toward BLUEFIELD (Portions toll) (Crossing into VIRGINIA). 75.5 mi Map | Avoid
22. Merge onto I-77 S via EXIT 81 toward CHARLOTTE NC (Passing through NORTH CAROLINA, then crossing into SOUTH CAROLINA). 229.2 mi Map | Avoid
23. Merge onto I-26 E via the exit on the LEFT toward CHARLESTON. 52.9 mi Map | Avoid
24. Merge onto I-95 S via EXIT 169A toward SAVANNAH (Passing through GEORGIA, then crossing into FLORIDA). 452.1 mi Map | Avoid
25. Merge onto OKEECHOBEE RD/FL-70 W via EXIT 129 toward OKEECHOBEE/FLORIDA'S TURNPIKE. 1.0 mi Map | Avoid
26. Merge onto FLORIDA'S TURNPIKE S via the ramp on the LEFT toward MIAMI (Portions toll). 106.3 mi Map | Avoid
27. Keep RIGHT to take FLORIDA'S TURNPIKE S/FL-821 S toward HOMESTEAD (Portions toll). 47.8 mi Map | Avoid
28. Turn SLIGHT RIGHT onto US-1 S/S DIXIE HWY/NE 1ST AVE. Continue to follow US-1 S. 34.9 mi
Thanks in advance,
Chris
You should be able to cover a leg without filling up on a 24 hr station. Just make sure you fill up before the DRY counties.
The RX typically has a cruising range of 390 miles and your route is mostly turnpikes and interstates. Finding gas at any hour should be no problem, especially using the truck stops.
Truck stops like Petro are abundant in the states and are open 24x7 all year. You will have no problem finding open gas station along interstates.
Super Moderator
Hello All,
Thanks in advance,
Chris
Thanks in advance,
Chris
You also should have continuous cellular telephone coverage (with major cellular companies like AT&T, Verizon) on the interstates. I agree with previous posters that finding 24 hour gas stations on interstates should not be any problem. I do the Wash. DC to So FL route several times a year.
I have traveled numerous times between FL to PA and back over the years on non-stop trips using much of your same route. Never had a problem finding a gas station in the middle of the night. Just keep in mind that the larger cities on the route will be your best bets and do not hesitate to fill up even if you do not need it. I usually found a place to stop around 10-11PM for a break and a snack, filled up with gas and was good until morning.
Also, fill up before you get to WV. You can fill up again once past. And, I think you should consider avoiding that whole US19 bit through WV if at night. Take a closer look.
ShunDoe
02-25-16 05:45 AM
