does your 07 RX350 have a TPMS sensor on the spare tire?
Old 02-17-10, 05:36 PM
SACrx350
SACrx350's Avatar
Default does your 07 RX350 have a TPMS sensor on the spare tire?
my tire pressure light is on, my spare doesnt have a pressure sensor on it, just wanted to know if thats the problem.
I dont know if it suppose to have a sensor or not.
Old 02-17-10, 06:03 PM
cmichael
cmichael's Avatar
Yes; my 2007 350 has the sensor.
Old 02-18-10, 04:45 AM
veleno
veleno's Avatar
and my 2008 does as well
Old 02-19-10, 12:25 PM
pauljcl
pauljcl's Avatar
and my 2009 does, too.
Old 02-21-10, 10:12 AM
nativecal
nativecal's Avatar
How would you know? The sensor in INSIDE the tire.
I'm sure you have it. If by some magic (like the tire was replaced at one time w/o a sensor), the tire pressure light would be on 100% of the time. Those sensors are registered at the factory with serial numbers into your ECM. When one shows low pressure (or goes bad), the ECM lights the dash indicator.
There is no easy way to verify that these work as they are programmed by the factory scan tool. They CAN be broken at "Tire Stores" when you get new tires, alhough most are used to them now. I still make it a point when I get new tire to insist on the invoice they put down that the light is currently "off" before the new tires are put on.
They are rather expensive (around $200). You can get used ones ($20) on Ebay and various other places, but used ones are usless if you don't have access to a FACTORY scan tool.
Old 02-23-10, 08:55 AM
geko29
Super Moderator
geko29's Avatar
TPMS sensors have metal valve stems. Tires without TPMS have rubber valve stems.
I've verified the spare on my 2007 has a sensor both by the presence of the metal valve stem, and by the fact that the warning light has come on (and stayed on) while all 4 service tires were properly inflated. Inflated the spare to the correct pressure, and voila! The light goes off.
Old 02-23-10, 12:20 PM
Rainbird
Rainbird's Avatar
Yes, the 2007 spare has a TPMS. I have had the light come on numerous times because of a low spare tire pressure. I now over-inflate the spare, problem solved.
jeff1rey
ES - 5th Gen (2007-2012)
10-17-19 11:46 AM
cwmoore
12-21-17 11:56 AM
kknguyen11
10-01-14 04:16 AM
Marexus
01-12-12 06:15 AM
LIMS407
01-24-11 07:07 PM
Quick Reply: does your 07 RX350 have a TPMS sensor on the spare tire?
