What's going wrong, need help
Old 10-13-09, 04:26 AM
tromly
tromly's Avatar
Default What's going wrong, need help
On two occasions within the last three weeks, my wife's 04 has had this problem. She's just cruising along and suddenly the following lights come on, brake, abs, tire pressure, and trac control. She pulls over and stops the car, restarts and the light are off, what gives?? Is it a defective sensor and should I take it to the dealer for service ?? Thanks for any assistance
Old 10-13-09, 06:51 AM
jfelbab
jfelbab's Avatar
Take it to an AutoZone and ask them to read the computer codes. Should be a free test. Or, take it to you Lexus dealer.
Old 10-13-09, 07:23 AM
visual
visual's Avatar
My wife 05 RX had the same problem. The brake, abs, tire pressure and trac control light came on. It only happen 3 times with my car, and it was off and on thing.
I think I resolved this problem by removed some of the brake fluid in the reservoir. Mine was overfill. I also reset the car computer with the battery negative terminal.
I have not see the light for months now.
When it happened, the scanner did not pickup any code.
Old 10-13-09, 03:55 PM
tromly
tromly's Avatar
+1, thanks for the advice, found out from a friend that it may be a faulty brake pedal switch, Lexus may have a recall out on it.
Old 10-14-09, 10:23 AM
visual
visual's Avatar
I will report back if the lights come on again, but lately it has not come on. BTW, please let me know if you able to resolve the problem with the brake pedal switch. I did some searching and it also pointing to the faulty of the tpms sensor on each wheel.
Old 10-15-09, 02:01 PM
hyiu
hyiu's Avatar
I have a 2006 RX330, also same problem.
In the middle of driving, (no skidding, not wet surface, no big bump)
suddenly, I see the brake light, VSC light, and the tires pressure light came on.
I pulled over, shut down and restart the car, and back to normal.
Happened a few times, pretty random, weeks apart.
I don't think the brake fluid was overfilled, but will double check.
Would really appreciate if you can let us know the part# and cost of the faulty brake pedal switch. I assume its just one switch ? or one per wheel ?
Thanks,
Old 10-15-09, 07:10 PM
arnieosp
arnieosp's Avatar
Actually, it's the brake LIGHT switch (no, I am not trying to be ****), and it had been discussed here: https://www.clublexus.com/forums/rx-...n-driving.html
Good luck.
Old 10-16-09, 03:18 AM
visual
visual's Avatar
Thanks arnieosp
Look like there is a recall on this. I also found the brake light switch online for $17
2004 Lexus RX330 Recall
Item Affected: EXTERIOR LIGHTING:BRAKE LIGHTS:SWITCH
Date Announced: 11/23/2004
Description of Recall:
CERTAIN PASSENGER VEHICLES MAY BE EQUIPPED WITH AN IMPROPERLY DESIGNED BRAKE LIGHT SWITCH. A SILICON OXIDE BUILD-UP OCCURS ON THE CONTACTS INSIDE THE BRAKE LIGHT SWITCH, WHICH CAN MAKE IT INOPERABLE.
Action Needed To Fix It:
DEALERS WILL REPLACE THE BRAKE LIGHT SWITCH. THE RECALL BEGAN DURING DECEMBER 2004. OWNERS SHOULD CONTACT TOYOTA AT 1-800-331-4331.
Old 10-16-09, 04:40 AM
visual
visual's Avatar
The previous owner had the same problem with the lights a year ago. According to the service record, the tech cleared the code (C1223 AND C1249) and adjust the Brake KE Lamp Switch.
Old 10-21-09, 01:56 AM
tromly
tromly's Avatar
I have an appt today at the Lexus dealer, will report findings. Thanks for all your assistance.
Azbrigada
05-08-12 07:41 PM
DUKE34
RX - 1st Gen (1999-2003)
11-18-09 09:08 AM
Jace_91
05-14-09 03:13 PM
whomiked
Performance & Maintenance
27
08-24-07 07:56 PM
dolesun
Suspension and Brakes
02-01-05 07:08 AM
Quick Reply: What's going wrong, need help
