What are the 2 switches for?
I found switches 2 on the driver's side below the dash board and one under the passengers side glove box
What are these for?
What are these for?
Page 307--309 of that thing called the owners manual
(..) set is for tire pressure monitor when you install a new tire or just to reset your pressures
Trac off disables your traction control--I know for 08 models you can hold that button and it turns off both TRAC and VSC until you restart vehicle--thats going to make some fun in the snow for me this winter Ill be out of control.....lol
Main and 2nd set is for your tire pressure sensors as well--always on main cause thats what is on your car. Say you have another set of tires (snow tires)--differant pressures ect....set that to 2nd set of tires if you have the moitors installed in those tires???
Super Moderator
New for 06 or 07 I believe. It was when Lexus switched from passive TPMS like we have in the 2004/2005 and possible the 2006 RX to the Active TPMS where you need special valve stems that measure the tire pressure internally and transmit that data back to the car wirelessly.
The sensors cost a lot...
