View Poll Results: What gas do you put into your 2RX?
Premium
0%
Medium
0%
Regular Unleaded
0%
Voters: 0. You may not vote on this poll
Do you need Premium Gas in the 2RX (merged discussion threads)
#63
Forum Administrator
Monish, this has been discussed many many times - suggest you use the search feature to look over some of the previous threads please.
Here are a few examples I found by searching for 'premium fuel' in the RX330/350 forum.
https://www.clublexus.com/forums/rx-2nd-gen-2004-2009/91641-gas-for-rx330-official-position.html
https://www.clublexus.com/forums/sho...ht=premium+gas
https://www.clublexus.com/forums/sho...d.php?t=222156 rx350
https://www.clublexus.com/forums/sho...d.php?t=215869
Another similar poll; in that thread I link others found
https://www.clublexus.com/forums/sho...remium+regular
etc etc
etc etc
#64
Premium Gas on the RX350?
I just received my new 2007 RX350 and I'm confused about the fuel requirements. I have a friend who tells me that Lexus will void your warranty if you use anything but premium fuel. True or False?
Has anyone used lower grade and still been okay? Does it hurt the engine in the long run? Can you use it occassionally? What's the real scoop?
Lindy
Lindy
#65
Lexus do not void your warranty if you use the regular fuel.
I use the lower grade, it's fine and I can't tell any difference between mileage using regular or premium fuel.
https://www.clublexus.com/forums/sho...highlight=fuel
#71
My brother has RX330 and the manual said 91 is recommended, however, on my 350, I think 91 is required.
I brought this question to my dealer and he told me I can use any type of gas, when engine knocks, then switch to higher octane.
#72
Super Moderator
With gas used in U.S. and Canada, should not have a problem.
With my RX300 where I live, I always used Premium 92 Octane Pemex (one nationalized gas down here) and it had much higher sulfur content than the U.S. Recently, they switched to one that was in the 200ppm+ min. down to one that has about 30 to 80 ppm, and I can notice the difference.
Modern vehicles can get used to different octanes pretty quickly.
#75
This is what Lexus sent to me after my repeated questions and trying to pin them down about warranty verses using regular gas"
"The warranty covers failures which are a direct result of a manufacturing defect during the warranty period as detailed in your Owner's Manual; therefore, if you do not use a gasoline that meets the requirements in your Owner's Manual and a failure occurs which can be attributed to the use of a non-recommended gasoline, this would not meet the criteria for warranty coverage."
