View Poll Results: What gas do you put into your 2RX?
Premium
0%
Medium
0%
Regular Unleaded
0%
Voters: 0. You may not vote on this poll
Do you need Premium Gas in the 2RX (merged discussion threads)
MultiTasking Mom
I read a USA Today review that said 91 octane was "recommended" - what have you been filling in your new 330?
Just curious . . .
Just curious . . .
Re: What kind of gas are you using in your RX330?
Just curious . . .
Just curious . . .
John
Are you sure that's what it says in the manual? In my '05 manual, it says the car will run on regular, but premium is recommended for better performance.
It's been my experience, with my RX 330 and the Highlander before that, that I can run premium and the increase in gas mileage more than makes up for the increased expense; but you can run regular as it states in the manual.
jjbrahma (12-25-19)
Originally Posted by kriglv
I just bought 2006 RX330 in the manual it states that you have to use premium fuel; has anyone tried regular??
Premium, Mid-Grade, or Regular
I was thinking about purchasing a CPO 05 RX330. What kind of gas is required, recommended and/or preferred? Consumer Reports indicates that regular is fine. I though I read that the owners manual indicated the same thing, but several car review websites indicated Premium is required.
Thanks.
Thanks.
This has been debated a lot on the forum... you may want to search for it.
The 2004 Owners Manual says "Select octane rating 87 or higher. For improved vehicle performance, the use of premium unleaded gasoline with an octane rating 91 or higher is recommended."
I used to use mid-grade (octane 89) until gas prices went through the roof, then I started using regular 87. I didn't notice any real difference.
Regular Works just fine
When I purchased my 05 RX TC the dealer told me that all of the RX's they use for loaners are filled with regular. Most of the personel at the dealership who own RX's also just use regular. It's fine to run them on regular, if you want more performance such as acceleration then step up to mid or premium, or add octane booster. Here in Jamestown (ND) the current price of regular is $2.69 which is the highest in ND based on GasBuddy.com. The other day while in Bismarck saw it was $2.53 and topped off the tank before leaving. I realize East Coast and West Coast prices will likely be higher than around the Midwest. So if you want to save a couple dollars each time you fill up then use regular. Premium runs about 10 cents a gallon more around here so a complete fill up will run you about $1.70 more if you looking more for performance. Also per the leading consumer mag. the higher octane will usually not improve your gas milage, just your performance.
RX 350 gas requirements
Does anyone know if the RX350 can use Regular gas or does it require premium?
Also, can the RX350 run on E85 gas?
BTW. I have used regular 87 octane, ethanol based 89 octane, and premium in my 05 rx330. I have not noticed any significant difference. Since I live in corn country I usually use the 89 octane 10% ethanol gas.
