Installing/wiring LED DRL's (and turn signal)
Does anyone know how to install the following linked DRL's?
http://www.carid.com/lumen/led-dayti...-10791029.html
7.5" Length, 800 lumen (with Turn Signal, with Dim)
LED Daytime Running Lights (DRL) by Lumen®, 1 Pair. Set of two add-on LED light assemblies, each measuring 7.5" x 0.78" with 800 lumens of light output. Lights dim automatically when headlights are on. Each light switches to flashing amber light to match corresponding turn signal operation. Corrosion-free aluminum and stainless steel construction. 50,000 hours lifespan.
In Stock - Usually ships within 24 to 48 hours
Thanks in advance for any ideas.
Welcome to CL.
Best advice would come from the manufacturer (lumen).. they have a contact listed.
Check with them how to integrate with the existing DRL on RX.
Salim
Salim
If you want an independent system then you might be better off.
Salim
Thanks Salimsha. I have tried to locate a fuse for the turn signals and park lights, but no luck. The only fuse box I can find is under the hood. I also checked the driver side kick panel and wiring, but not a fuse box. Any thoughts?
Thanks
Thanks
Take the coin box (near driver left knee) out and you will see the fuses. You will need wiring diagram to figure out the right fuse that you want to tap into.
Salim
Salim
Yes, found the fuses behind coin box, but to no avail. I have since requested further instructions from Lumen and should have in couple of days. Also, got an estimate today fro auto shop for around $250 to install.
So, hoping Lumen instructions will allow me to do myself??
