2000 RX 300 fan noise/baffle after ignition is off
Any idea how to DIY fix of fan noise or baffle whining after the car is turned off. Only last 5 to 10 seconds then stops. Also noise when the fan on in cold weather. Once I turn up the heat above 75 it stops.
Charlie
Charlie
Is is more like a clicking noise?
This sounds similar to my air mix servo issue.
EDIT: Just noticed you said the noise continues after the car is turned off, if that is the case than the servo is not the cause.
