RX300 rear washer does not work
Old 04-03-14, 05:16 PM
HadYurPhil
HadYurPhil's Avatar
Default RX300 rear washer does not work
Anyone had this problem? Where should I start>
Old 04-03-14, 07:11 PM
carguy07
carguy07's Avatar
Does the front washer work?
https://www.clublexus.com/forums/rx-...tructions.html
Old 04-04-14, 10:52 AM
HadYurPhil
HadYurPhil's Avatar
Front one works fine. I assume there is a separate pump somewhere for the back.
EDIT: I read the linked thread. That's a big help!
Old 04-04-14, 10:57 AM
salimshah
Forum Moderator
salimshah's Avatar
Received 1,101 Likes on 991 Posts
Please read post #3 in the link provided carguy07
Salim
Old 04-04-14, 02:23 PM
Baetke
Baetke's Avatar
The pump is located behind the right front fender skirt. You can access it by removing the wheel and pulling the skirt away from the fender. The pump turns one direction to pump fluid to the front window and the opposite direction to pump to the rear window. If you access the pump you can disconnect the hoses from it and verify that the pump works. If it does then you have a clog in your tubing somewhere. Access the rear squirter and blow air or water through it in the reverse direction to clean it out (with the hose disconnected from the pump of course).
Oro
12-31-16 02:36 PM
sifonter
02-27-12 05:59 AM
biggywilly
12-23-09 05:18 PM
dscholl
SC- 1st Gen (1992-2000)
02-17-09 08:11 PM
Quick Reply: RX300 rear washer does not work
