Rough Idle/shaking, Blinking Cil, Replaced Ocv 4 Mo Ago
#31
Start a new thread for a new problem ,,, and it goes without saying that please use search and add to an existing thread which relates to your problem.
item #2. Please look through Having Problems start here Mega thread (sticky).
item #3. Ignore till it comes back . Also try to fill when the tank is 1/3 -1/4 full.
item #4. Clean MAF. Replace air-filter (30-40k interval). Reset ECU
Salim
Salim
Regarding 1, is this related to the rest of this, or should this be a new thread as well? Smell of exhaust comes into the car as well.
ALSO, I wanted to be sure to fully thank you for all your help through this. I was on the edge of selling this car, but now that the coils/plugs are replaced and it's running so well, I think I'll just keep it! over 220k miles and runs just amazing.
#32
Thank you. Will start new thread for items 2, 3, 4.
FYI. I am going to be replacing the solenoid connections and plunger from amazon for 13 bucks. That is supposed to fix the coming starting issue.
Tomorrow I am going to remove the battery cables for 30 minutes to reset the ECU as I am not sure this was done when i took it in for the coils/plugs.
Whats my next project likely to be?
#33
Dont make it a project car. Just fix the problems and catchup with maintenance items.
Salim
Salim
