RX300 Transmission Fluid Change FWD
Changed my ATF this weekend, dropped the pan, changed the filter. cleaned the magnets, and used the transmission to pump the old fluid out as described before. All went well.
I can confirm that on the 2WD cars, the return fluid line from the radiator back to the transmission is the passenger side hose.
I slipped it off at the radiator, used a 3/8id clear tube from the hardware store, and ran the engine, pumping out a lot of the old fluid. When it got better looking, not perfect, I stopped and reattached the hose.
Doing it this way, I removed about 9.5 quarts of fluid.
hardimen
10-02-12 12:51 PM
