AT Temperature light on
Old 07-31-13, 01:32 PM
imikekimi3
imikekimi3's Avatar
Default AT Temperature light on
Hello!
I own a 99 Rx300 with around 211,000 miles on it.
I had two long trips (greater than 3 hours) where my A/T temp light came on. If i pulled over for 5 minutes or went below 60 mph the light disappeared. Does anyone know what is happening?
I am about to take it to pep boys. It has been running fine since then
Couple Side notes:
- Mechanic told me to use regular conventional with lucas oil stabilizer with my high mileage car. I feel like this has something to do with it since I first saw this light appear after I used Lucas oil stabilizer
- Car has been giving a burning smell for quite some time but I attribute that to the oil being burned off.
-Catylitic and O2 sensor light is on but i Dont think that has anything to do with the current problem
- Car struggles with changing gears especially from RPM 2- 3
Also does a kick back sometimes when I go into reverse. Please let me know! Thanks!
Old 07-31-13, 01:50 PM
Dadikins
Dadikins's Avatar
AT light is automatic transmission temperature!
Check the level & condition of the transmission fluid NOW. When was the last time it was changed? Would highly suggest several drain & fills.
Old 07-31-13, 06:56 PM
thomas1
thomas1's Avatar
Yep check tranny fluid and do not under any circumstance do a flush.....I repeat do not do a flush, drain and fill only.
Old 08-01-13, 07:38 AM
lexus114
lexus114's Avatar
I think this is the first time I have ever heard of this light coming on? LexMex used to race his in Mexico, and never had his light come on?
Old 08-01-13, 08:19 AM
Lexmex
Super Moderator
Lexmex's Avatar
Correct, I've never seen it come on.
Old 08-02-13, 07:16 AM
lexus114
lexus114's Avatar
Well Lex, at least he know`s his temp light works! : P But as far as the symptoms, I would start where the others have mentioned^^. And the codes might be affecting the transmission performance.
Old 08-02-13, 07:37 AM
Lexmex
Super Moderator
Lexmex's Avatar
I would check the the tranny fluid immediately upon getting home if I got one of those.
Old 08-05-13, 06:29 AM
imikekimi3
imikekimi3's Avatar
when i took it to pep boys (they dont do tranmission)
the guys said sometime the computer will trip the light to come on especially if I have unmatching tires (which I do). I dont know how legit that is but it sounded pretty good lol. Ill be taking it to a transmission shop soon. TY everyone
Old 08-05-13, 04:28 PM
kalali
kalali's Avatar
Well, how hard is it to check the condition of the fluid? I have a feeling we'll be seeing a new thread asking for recommendation for a good place to rebuild transmissions.
Old 08-05-13, 05:16 PM
carguy07
carguy07's Avatar
...No
Kaius88
ES - 5th Gen (2007-2012)
30
04-12-18 05:32 AM
Leines
03-29-13 10:51 AM
GSspeed
Maintenance
11-15-06 07:55 AM
purebliss
Maintenance
07-11-03 05:37 PM
Quick Reply: AT Temperature light on
