Brake Fluid Change Interval
Old 07-08-13, 09:46 AM
Bclark
Bclark's Avatar
Default Brake Fluid Change Interval
Car: 2001 RX300
Miles driven per year: About 5K
Question: When should I change my brake fluid?
Does anyone have recommendations when I should change my brake fluid if I only drive about 5000 miles per year and the owners manual says to change brake fluid every 30K miles?
If I go by the owners manual, it would take me 5 or 6 years.
Thanks.
Old 07-08-13, 10:00 AM
salimshah
salimshah's Avatar
Brake fluid should be changed every 2yrs independent of milage.
If you dont use your vehicle, it is more important that you purge and refill
Also try using a fresh can of brake fluid. Half full/empty bottles tend to pick up moisture.
Salim
Old 07-08-13, 02:36 PM
hypervish
hypervish's Avatar
Salim
+1, Every 2 years.
Old 07-12-13, 11:50 AM
trhs75
trhs75's Avatar
I've read some people use colored fluid to make sure they get all the old fluid out. Does anyone know where to get it?
Old 07-12-13, 04:42 PM
bob2200
bob2200's Avatar
Default Colored Brake Fluid
I have used ATE brand. It comes in both clear and blue. I have gotten it mail-order, but performance auto stores may carry it.
Old 07-12-13, 08:03 PM
trhs75
trhs75's Avatar
Thanks, Bob! I'll write that down!
Old 10-02-13, 01:24 PM
zietsman
zietsman's Avatar
my car mat under driver pedals is wet and also left and right corners of backseat mat is also wet. can anybody please help me with what it could be and it is a 2005 rx 300
Old 10-02-13, 01:30 PM
salimshah
salimshah's Avatar
You need to investigate what is the fluid ... most likely it is water ... from rain or ac-condensate. Both have been discussed and search can find those threads for you.
You should also check fluid levels (weekly if not monthly) and a drop in any would indicate a leak.
I think your problem has nothing to do with the brake.
Salim
qiphlow
NX - 1st Gen (2015-2021)
03-06-17 05:26 PM
matts6887
20
04-19-16 06:40 PM
Llopez
Suspension and Brakes
01-30-10 04:59 PM
Joeb427
11-15-07 01:17 PM
johnp
Maintenance
15
09-27-02 10:49 PM
Quick Reply: Brake Fluid Change Interval
