Downstream O2 bracket broke off
Old 09-21-12, 05:35 PM
IndyRX300
IndyRX300's Avatar
Default Downstream O2 bracket broke off
The JB Weld Stick held on for a little over a month then broke off again. After last fill up ,my wife was already at a half tank after 80 miles. Needless to say this is an expensive problem. After shopping around online , it seems that I am going to have to buy another cat in order to get a new bracket. One of the studs was already broken off and I broke the other one trying to put a new bolt on.
Do any of you know if it is possible to just buy this bracket of am I going to be out $200 + ?
Old 09-21-12, 10:31 PM
salimshah
Forum Moderator
salimshah's Avatar
Received 1,101 Likes on 991 Posts
JB Weld cant stay for long due to high temperature.
I would suggest that try an exhaust shop and see if they can weld some thing.
Salim
Old 09-22-12, 06:12 AM
JAB
JAB's Avatar
I had the same problem that I think you are describing. Midas exhaust shop charged me $150 to fix.
Old 09-22-12, 01:08 PM
IndyRX300
IndyRX300's Avatar
Update - "studs damaged beyond repair" per car x. They did not try to sell me another cat which was nice. They did quote me $75 labor to put a new flex pipe on. Found Bosal pipe for $85 and a walker for $65. I can cyber coupon and get either one for $30 less. I am leaning toward Bosal . Just concerned about fitment on either one. Advance auto claims exact fit.
Old 10-19-12, 05:08 AM
carguy07
carguy07's Avatar
Where were you finding the best deals on the Walker flex pipes?
Thanks!
Old 10-19-12, 10:59 AM
carguy07
carguy07's Avatar
Never mind, ended up using Advance Auto with a coupon code. Pipe and gaskets were $61.84 not bad at all. Now I just have to get those front bolts to break loose.
Old 10-19-12, 04:10 PM
hypervish
hypervish's Avatar
Let me know how the job goes. I plan on trying to DIY the front flex pipe in a few months. What gaskets did you need to buy?
Old 10-19-12, 07:04 PM
carguy07
carguy07's Avatar
Yep, I'll let you know. I got part #'s 31332 & 31374, front & rear. Hopefully those are correct.
Old 10-21-12, 06:32 PM
IndyRX300
IndyRX300's Avatar
Sorry for responding so late. You do know that you can use more than one coupon thru Advance Auto?
That is where I was getting the crazy deals. I usually end up with free stuff after it is all said in done. I know I got a 3M lens kit for free after doing what I call "Extreme Cyber Couponing" thru Advance
I got a crazy deal on my Bank 1 A/F sensor as well. Cheaper than what you can get on Amazon. Not to mention it was Denso.
Old 10-21-12, 06:43 PM
carguy07
carguy07's Avatar
I have only gotten the double coupon thing to work once on their site. I think it was a labor day sale that worked with one of the regulars. Which ones are you having luck with?
Old 11-10-12, 10:11 PM
carguy07
carguy07's Avatar
Well I replaced the pipe today, or really I should say I had it replaced. The front 2 bolts came out easy with an electric impact. The rear ones just rounded off the heads. So I used an angle grinder on one, but I was eating a face full of sparks and fire and what was left of the bolt was still stuck in there. So I borrowed a torch and tried to cut the other one off. Just ended up making a mess of the bolt and could never get it cut off cleanly. With a lift it would have been a piece of cake, but on my back with my face up there made it very uncool. So I finally punted and went to a local muffler shop and gave them $70 to finish what I started. Took them maybe 5-10 minutes. Paid way to much for what it was, but after fighting it for a long time and busting up my hand and somehow sitting up and catching my face with the license plate, I was ready to pay a few bucks and call it a day. The walker part seems like a very good quality replacement.
frankf2014
05-15-17 09:05 PM
Devor
SC- 1st Gen (1992-2000)
01-21-11 02:47 PM
Lexmex
46
11-27-07 07:09 AM
sumotime
Performance & Maintenance
09-13-07 12:20 PM
kate
12-02-05 08:12 PM
Quick Reply: Downstream O2 bracket broke off
