Black smoke,no o/d shift , horrible gas mileage
Old 07-29-12, 12:48 PM
thomas1
thomas1's Avatar
Could you have a bad oil control valve?
Old 07-29-12, 12:59 PM
IndyRX300
IndyRX300's Avatar
I have no clue what so ever. It does seem that it is using some oil but no idea if that is related. Is that an interal component?
Old 07-29-12, 06:00 PM
carguy07
carguy07's Avatar
Disconnect the battery and see if that code goes away.
Old 07-29-12, 07:50 PM
thomas1
thomas1's Avatar
there are two oil control valves for the camshafts...variable timing. do a search on this forum and their are entries of where they are located. The codes are absolutely necessary....
Old 07-29-12, 11:16 PM
salimshah
salimshah's Avatar
Originally Posted by IndyRX300
Well I found the exhaust leak. The downstream 02 sensor has broken off and is just hanging there.
Transmission is shifting fine today so there is something intermitent. I am going to see if I can somehow get the 02 sensor remounted. We cannot afford a new exhaust at the moment. I see some jbweld in the future. I hate putting bandaids on but I do not want my family poisoned either.
JBweld can not maintain hold due to high temp. Weld or brazing is needed if possible.
Salim
Old 07-30-12, 11:57 AM
IndyRX300
IndyRX300's Avatar
Salim
I used the JB weld Stick. It claims to hold temps up to 500 degrees. So far so good
http://jbweld.net/products/jbstik.php
I reset the computer and the light has not came back. She seems to be running much better now. Crossing my fingers.
Just an update. Everything is running good. Now avg 19.3 mpg +/- the variance of the cpu. This is in stop and go traffic on the highway. After the smell of the residual jb weld finally went away, the car is much more quiet and no check engine light.
LexStylez
02-12-19 05:51 PM
Michael361
10-21-13 10:04 AM
RXGS
04-12-13 04:36 PM
DeanGS
06-06-11 08:21 AM
ual320jet
09-17-10 09:14 AM
Quick Reply: Black smoke,no o/d shift , horrible gas mileage
