Preparing for 90K service- any advice?
I'm using a local (trusted) mechanic for my '03 RX 3000 90K service.
OEM parts only. Any words of wisdom from the group? SHould I be using OEM fluids as well?
I'm a bit anxious about transmission issues. I've never had any problems on this car, but also don't want to stimulate anything bad.
Yes stick with Toyota Red or pink coolant, and Toyota Type IV transmission fluid....Do not do a flush, drain and fill only. The timing belt is do, however it could go 100k miles. Have him check the water pump for leakage while doing timing belt as the belt drives the waterpump. Spark plugs arent do until 125k miles easily. So the most expensive thing is the timing belt change.
For a drain and fill you will need 5 quarts of Toyota Type IV fluid for the coolant you will need two gallons of the premixed, or 1 gallon of the regular cooland which you would mix 1 gallon of distilled water with it. I Think the RED (Toyota) fluid is the regular and the pink is the premixed....However remember it is expensive coolant but will last 5 years or 150k miles.....
[don't worry about transmission] as in 1) just leave it alone or 2) drain and fill it.
I happened to be near a dealership today, and spoke with a Service Advisor. He indicated that often if nothing has happened by 90K, it's best not to disturb the tranny and not change any fluids (assuming they look ok). This is the first I've heard of this....
wing0
RX - 1st Gen (1999-2003)
08-18-13 06:12 PM
deanbrown
13
09-30-05 12:45 PM
