Air conditioning blowing hot, hot, and hotter .... help
Old 04-13-11, 03:39 AM
barbwebb
barbwebb's Avatar
the lights did go away when I disconnected but when I was checking the servo motors while the car was running just as I turned the AC on they came back on. When I corrected the flap so the AC would blow the lights went out and has not come back on. Yes I agree this is puzzling but I am not gonna grip I am gonna be thankful that everything is working the way it should. If...I hope a big if they come back on I will have them read again...then you guys can listen to me again..lol
Old 07-10-12, 01:06 PM
Francis
Francis's Avatar
Originally Posted by barbwebb
Phillips head screwdriver, plyers, and 10mm socket and now my AC works.
Where is the servo motor? Does it near the air filter or the radiator?
Old 07-10-12, 01:45 PM
gazi001
gazi001's Avatar
It located near the left side of the glove box. Here is the pic.
Attached Thumbnails Air conditioning blowing hot, hot, and hotter .... help-5068220025_e38e569679_z.jpg
Old 07-10-12, 02:40 PM
Shift_RX
Shift_RX's Avatar
Thanks. I learned something new today. Going to stash it in my lexus toolbelt of knowledge
Old 07-10-12, 04:39 PM
GaRobert
GaRobert's Avatar
Hey Barb.. I have just the other problem, I have no heat. Looking at the picture you posted it looks like the lower servo . Salim give me information also. How hard was it to get to that unit. Not as young as I use to be, so the body is not as limber as it use to be.
Old 07-10-12, 05:27 PM
salimshah
salimshah's Avatar
Please verify the compressor and refrigerant are working. This can be done by checking the high pressure line from compressor is cold. If that is all good then look at the mix servo.
Salim
Old 07-10-12, 11:12 PM
gazi001
gazi001's Avatar
Here is the link for DIY:
https://www.clublexus.com/forums/rx-...vo-arms-2.html
Old 07-16-12, 06:42 AM
barbwebb
barbwebb's Avatar
it was actually very easy.
there is 2 screwes in the glove box once thats removed you can remove the duct and everything is visible to the lower left of the glove box.
Old 07-28-12, 07:46 AM
juaid86
juaid86's Avatar
hi, i have the same problem the ac keeps going hotter and hotter and i filled it up with freon once and within 1 week it started to get hotter again, could it be the servo mixo thing???
Ahmed
Old 07-29-12, 10:01 AM
Iluvlexus
Iluvlexus's Avatar
Just finished replacing my air-mix servo after 2 attempts at repairing the existing one using the "rebuild" techniques described by others in this forum. The servo would work for a while and then fail again and it is a bit of a pain to remove so I finally bit the bullet and bought a new one.
No AC could be the servo or the compressor or a freon leak. First run your AC for a few and check the temperature of the lines coming from the compressor. If the are hot and cold the problem is likely the servo. I found the best tool to remove the screw behind the heater pipes to be a small slotted screwdriver which can be placed between the pipes. I have gotten pretty good at this removal/reinstall and can now do it in 30'.
You can temporarily resolve the servo issue by loosening the screws holding the servo and disconnecting the servo arm from the air mix lever. The lever will assume the cooling position.
Good luck
Old 10-06-19, 10:45 AM
jamsk8s
jamsk8s's Avatar
Default 2001 leaxus rx300
I just bought this car and same issue just heat blowing out. Tomorrow I will try to access the servo motor and push the White clip up or down to see if this changes. I'm hoping for the best. Thanks
Old 10-06-19, 02:50 PM
salimshah
salimshah's Avatar
Start by checking if there is chilling going and condensation is dripping (assuming you have humidity), check the AC clutch and see if the load and rpms get affected by the AC being turned on [2nd electric fan should kick in too]
Salim
honeygee2
07-31-12 10:41 AM
MysteryFan
15
03-09-11 05:22 PM
bobsobi
ES - 5th Gen (2007-2012)
01-11-10 10:00 AM
smerre01
01-25-09 03:36 PM
Quick Reply: Air conditioning blowing hot, hot, and hotter .... help
