Engine Oil Leakage, help please.
Hello Guys,
I have a 01' RX300 2WD 110k, a few days ago I found some oil mark on the ground and checked the underneath of the engine compartment and the engine oil pan area. Sadly, there is some oil leakage out there. From the color and the viscosity, I guess it is most likely the engine oil leakage. I attached some pictures taken from under the engine. There is no leakage found above the engine in the compartment. Would you guys give me some hints what is the most possible leaking area? Many thanks.
I had the same problem. I tighten the four rear bolts on the rear valve cover and the leak went away. When I get my timing by done, which is soon, I'm gonna have them replace both valve covers while they are in there. But for now just get an open end wrench in there and tighten the bolts just a half a turn each. Not too much.
I agree, it seems to like it's coming from the rear valve cover. Tightening the screws is just a temporary fix, you will probably have to replace the gasket down the road.
The best time to do it, is probably when changing the spark plugs.
Thank you all for the quick solution, now I have an idea what is the problem. Do you guys know how much to change the gasket for rear valve cover?
BTW, I did oil change at Lexus before. Since last time (6k ago), I went to Toyoya, but used the Oil I bought from Lexus. Hope this change is not the cause for the problem.
It could be if you switched your oil from synthetic to regular. Or visa versa. I went from regular to synthetic and it started leaking a bit. Mine was worse than yours. Every once in a while, I get a little drop or two on the driveway but rarely after I tightened the bolts. And definitely having the spark plugs changed along with valve cover gaskets when I get the timing belt done...
I have the same issue with the rear valve cover oil leaking. Seems like to replace the rear valve cover gasket, you need to remove the intake manifold. Replacing the rear spark plugs you don't need to remove the intake manifold. Hope there is DIY for the rear valve cover gasket.
Well, I am not sure what oil was used at Lexus. Last time before I went to Toyota, I went to Lexus and asked them give me the same engine oil Lexus used, then took it to Toyota. My purpose was to let my engine use the same oil consistently. Maybe the Lexus sold me the wrong engine oil. Plan to to let Lexus do the next oil change in a few days and then report the outcome.
PCV wont do much for you.... its more than common for the valve covers to go around 90k its totally common, take into account that the camshaft seals leak aswell and last about aslong as the valve cover gaskets on these engines. Since you're at 90k+, I'd say do the valve covers, t-belt and while the tbelt is out, change out the cam seals. All your problems will be gone.
Thanks. BTW, I forgot to report: after replacing the pcv, the oil leakage stopped. I wouldn't say 100%, but certainly not noticeable. Will see how long it last.
