Will these rims/tires fit???
http://barrie.kijiji.ca/c-cars-vehic...AdIdZ250425059
or these
http://toronto.kijiji.ca/c-cars-vehi...AdIdZ248504908
I have already bought spacers for the back tires to make my snowtires off a toyota highlander fit... i believe they are 1/4" spacers?? if that makes a big difference for the offset...
Cheers
or these
Cheers
Its hard to tell without the specs of the wheels. But the tire size should be ok. If that dodge magnum is RWD it shuold fit as they are low offset. But if the magnum is AWD they use a high offset so it may touch the rear suspension.
I'm surprized you need to use a spacer for highlander wheels because its the same chassis as the RX.
But personally I would stay away from those wheels. For one they are fugly a hell and chrome is so outdated and being you live in Toronto its only a matter of time it pitts and flakes off
I think the issue was the tires were off a FWD highlander and i have an AWD rx...... Im under the impression the AWD has like a +30 offset on the rear.... Im not too worried about the chrome flaking, i wont be driving them between sept-may.... I just figured for $800-1000 i could get 4 20'S and tires it would be worth it if they can fit....
Cheers
Cheers
