Transmission or ECM? That is the question.
Old 10-27-10, 12:24 PM
Arroz
Arroz's Avatar
Default Transmission or ECM? That is the question.
I have a 2000 RX300 (6/2000 FWD) with 145k. The engine was replaced at 100k due to sludge issue prior to my ownership. It had what appeared to be the signs of transmission failure - P1730 (speed sensor) code, not shifting into overdrive, and the occasional hard shift into second. First I confirmed that the speed sensors were good, then the wiring to the ECM were ok. Second, a drain and fill which showed a little to much metal. I proceeded to put in a new transmission only to have identical symptoms of P1730, no OD, and hard shifts. My only thoughts prior to taking it to someone else is swaping the ECM and all that entails. I'm looking to you folks for any other ideas? Thanks
Old 10-27-10, 03:20 PM
thomas1
thomas1's Avatar
Swap the two speed sensors and see if the symptons change, when the replaced the tranny they probably used the existing sensors......
Old 10-27-10, 03:32 PM
Arroz
Arroz's Avatar
I first tried swapping the sensors, then tested both of them (even though one of them is brand new!) and no change in code, still P1730 once I hit 30mph. I've reset the codes by scanner, fuse removal, battery cable removal, and even did the old GM trick of touching the positive and negative cables together for 15 seconds (without any power to them of course) and nothing has changed.
masonshear
12-17-17 07:05 AM
mityfang
07-06-17 04:55 AM
mityfang
07-05-17 11:14 AM
RX469
11-01-16 08:22 AM
jimsRX300
06-01-14 01:27 PM
Quick Reply: Transmission or ECM? That is the question.
