Tranny oil change
Tranny oil change
had my tranny power flushed and oil/filter changed at AAMCO. The pan didn't have any metal shavings, the magnets didn't either. The fluid was a dark cherry. The shifts are now much smoother. 2002 FWD 76k miles....
I don't think that was a good idea, but I wish you luck. And especially AAMCO I wouldn't let them even come within' 2000 feet of my car. You should have done a simple drain and fill, and if you did really want a flush (not recommended but) you should have atleast had it done by a good independent shop or toyota/lexus.
Alexus02
If you don't mind me asking, what lead you to have the tranny flushed? The toyota dealership from which I bought my 2002 rx 300 (I have it serviced there as well) recently recommended that I have the tranny flushed when we have our next oil change (scheduled for next month). My rx has a little over 70K miles and, based upon the dipstick, the fluid is still light red/pink. Based upon what I have read on this forum I have been hesitant to do it.
Thanks.
Thanks.
Alexus02
Thanks.
Thanks.
Alexus02
Thanks.
Thanks.
Always use a fluid compliant with Toyota Type-IV or else you'll have a tranny failure. I see your in Minnesota so you should be able to acquire Toyota Type-IV if your not interested in that fluid I would recommend Castrol Multi-Vehicle Import it is a synthetic blend opposed to the toyota fluid which is a dino.I myself use the Castrol and the RX hasn't ever shifted this well.
You will need 5 quarts. The drain and fill needs a little over 4 quarts so don't fill in all 5... Measure how much you drain and refill that amount with fresh ATF.
PS...Toyota Type-IV is the same oil as Mobil 3309 except it is just packaged with the Toyota name.
I think my Toyota dealership might mean a fluid exchange. I called a local Lexus dealership after getting the original recommendation and was told to avoid something they referred to as a backflow flush but that a flush, which as they described it was a fluid exchange, would likely be fine. I then called my Toyota dealership and asked them to described what the recommended "flush" entailed and it sounded like the procedure Lexus said was ok. Essentially, as I understood it, the machine would have two hoses, one of which would push new fluid in to the tranny while the other was used for the old fluid that was pushed out. I will know for sure next month when I bring the car in for service.
A Fluid exchange only uses the Cars transmission pump to move the fluid. Personally I dont trust the mechanics in general. I would do a drain and fill with a filter cleaning....I have had the fluid exchange done, but by my son-in-laws brother whom I do trust...on my Ford F150.....
UPDATE: 3000 miles and have not noticed any adverse effects from the tranny flush. Tranny changes are smooth, oil looks and smells like it should...more to follow if anything changes...
Alexus02
Thanks.
Thanks.
Bumbobee
21
06-05-14 04:27 PM
