slow acceleration + little shaking from engine in low rpms
#32
Hi Lexmex
I added the injector cleaner yesterday i have used untill now 50% of the tank there is no change ..im seriously getting myself together to clean the IACV just to rule that one out ...jerking and staggering in low rpms when i pass 1500-1600 rpm the car is smooth
#33
Update ...since i did not have any instrution manual on the car i could not reset the cruise info km/l or mpg as it is in us ...i found out to reset it ...i took a drive which prolly is classified as city driving ..i got 7 km/l on that trip so the gas consumption is not as bad as i earlier stated ..still not smooth in low rpm's
#34
Cleaned IACV took around 20 min thanks to the DIY ..it was not moving freely i cleaned it out untill moving freely ..if it solved the prob is to early to say ill go take a shower and hit the road ..and ill report back later
#35
Testdrive result ..seems smooth but the ride was short cause i now got a lamp on that says O/D OFF so it doenst change to 4th gear ...what happend ?...still no cel on
#36
ROFL..im an idiot its now confirmed... some moran<---"that would be me" pushed the button for overdrive and ofcourse the light turned on....longer test ride is needed + a driver with brain
#37
\o/ seems like the problem is gone just drove for 45 min smooth like silk ..
Lexmex was correct when he mentioned IACV and thanks to his instructions it was a walk in the park to clean it
my avg km/l was on this trip which i would call city 7.1 km/l or nearly 17 mpg ..it must be said the speed is low here usually between 20-50 kmh.
Thanks to all that gave a hand with this prob.
Respect _o_
Ow is there a way to disconnct the auto lock when u pass 20 km/h since its a bit annoying cause of the low speed we can hold here ?
Respect _o_
#38
Super Moderator
Respect _o_
Respect _o_
I am not sure what you are referring to on the auto lock. Are you perhaps referring to in the first few minutes after starting the vehicle up and going down the road that you can't shift up in gear? If so, that is something built into the programming for emissions reasons and also to give the fluids a chance to warm up. Or are you referring to something else?
#39
Hi Lexmex
no there is 2 buttons on my gear stick ..one for the release and one is for disable the overdrive ..i accidently pushed the smal button ..i didnt kow about that one since again i dont have the instruction book ..same with the horn i thought it wasnt working untill i realised it was the tiptronic gearshifter i pushed on ..anyone have a glue if a instuction/service book is online ..i got the repairmanual but that aint explaining bout the handling of the accesories ..
I just came home from town my km/l is now at 7.3 and it was smooth as silk i think we can conclude that IACV dont neccesarly means bad idle but can also mean bad driving in low rpms..
Next is changing battery im gonna try see if i can find a made in japan ..also on my waiting list disabeling the auto lock door feature which is annoying me..like this when i exceed 20 km/h the doors lock automaticly and when below 20km/h it unlocks them again ...since my average speed is at the moment 28 km/h its easy to see that i have a lot locking and unlocking going on.
The thing about the engine disable 4 gear when starting cold i never noticed maybe because it doesnt take long to get heat on engine when it allrdy at 40 celsius from the wheather.. only at night it get below 25 celsius
#40
Ow i see u like drag i have a friend from Denmark that likes fiddeling around with his jeep check it out there is quite nice videos from his races on youtube ..last i heard from him he pull close to 1000 hp out of it ofcourse when he use nitro
http://www.youtube.com/watch?v=Bp2rPdS7yp4&NR=1
#41
Super Moderator
#42
Super Moderator
Hi Lexmex
I have never heard of the door lock feature you are describing. The only things that remotely come to mind are a battery issue (getting old) or it is more likely related to CBEST settings. These are settings that could conceivably be set at a dealer with the appropriate tool to, among other things, open doors the way you want them to. The last thing that comes to mind is there is a grounding wire issue somewhere causing an electrical jolt to the doors and triggering the issue you describe.
#44
Okay i thought tiptronic was standard but i noticed u got cruise controlle i dont have that in mine so there is slight diffences from east models to west models ..the tipronic works smooth no probs there..im quite certain the autolock door thingy is standard here also but im gonna dig a bit into that issue..it could be a error i doubt it though its very consistent in doing it at exactly 20 km/h..i also saw on ure pic that ure speedometer goes to about 240km/h mine goes to 180 km/h
#45
Hi All
hmm my problem still remain.... unstable running in low rpms ...
my new airfilter will not arrive untill next week ..i took out the filter and testdrive to see if it was lack of air coming through..it got worse from removing airfilter so i dont have much hope in that a new airfilter gonna help me out ..
i still do not have a cel light on and i promise i lights on everytime i put ignition on so the bulp is working for sure ...i noticed also gearshifting is not as smooth as i think it should be ..same as b4 when i give some pedal and rpms increase im flying ..but in low rpms it not a pleasent ride at all...
The injection cleaner made no difference..i clenaned maf twice cleaned IACV it was dirty and did not move freely but even though at first it seemed fixed the problem still remain ..
Any suggestions on what i do now ..
