Extended warranty
Extended warranty
Does any one have extended warranty on you RX 300? A quote for mine (03 AWD with 51k mi) for full coverage is about $2000 for 4 yrs or 100k mi on speedometer. What is your opinion on extended warranty? If you are using it, how difficult is it when it comes to claim? which company?
Here is a comparison of quotes from 2 providers (WA Platinum and Integrity Automotive Protection (IAP) OEM) through autochex. IAP is the full coverage one. Another cheaper one is about $1100 and is limited to the transmission, engine (the main big items) etc..http://www.smartautowarranty.com/fil...Miles_Plus.doc
Components WA Platinum Integrity Automotive Protection (IAP) OEM
Seals and Gaskets optional yes
Wear and Tear optional no
Engine WA Platinum Integrity Automotive Protection (IAP) OEM
Engine Block yes yes
All Engine Internals no yes
Engine Cylinder Heads no yes
Engine Dip Stick and Filler tube yes yes
Serpentine Belt yes no
Engine Mounts and Torque Strut yes yes
Flywheel yes yes
All Pulleys yes no
Intake Manifold yes yes
Exhaust Manifold yes yes
Timing Belt yes yes
Piston Pins yes yes
Valve Guides and Seats yes yes
Harmonic Balancer yes yes
Engine Sensors no yes
Timing Chain Tensioner yes yes
Valve Springs yes yes
Vacuum Pump no yes
Air Cleaner Housing no yes
Push Rods yes yes
Hydraulic and Solid Lifters yes yes
Timing Gears yes yes
Oil Pump yes yes
Piston Rings yes yes
Thermostatically Controlled Air Intake no yes
Distributor Shaft and Housing yes yes
Transmission WA Platinum Integrity Automotive Protection (IAP) OEM
External Transmission Controllers yes yes
External Solenoids yes yes
External Transmission Linkages yes yes
Dip Stick and Filler Tube yes yes
Transmission Mounts no yes
Transmission All Internals yes yes
Vacuum Modulator yes yes
Drive Axle WA Platinum Integrity Automotive Protection (IAP) OEM
Spider Gears yes yes
Drive Axle Yokes no yes
Center Support Bearings no yes
4 Wheel Drive Locking Hubs yes yes
Universal Joints yes yes
Drive Axle Shafts yes yes
CV Joints yes yes
Locking Rings and Retainers yes yes
Electrical WA Platinum Integrity Automotive Protection (IAP) OEM
Distributor yes yes
Gauges yes yes
All Electric Motors yes yes
Relays, Pumps, Solenoids yes yes
Speed Sensors yes yes
Wiring Harnesses yes yes
Coil Pack, Ignition Coil, Electronic Ignition Coil yes yes
Wheel Sensors yes yes
Ignition Lock Cylinder and Ignition Switch no yes
Instrument Panel Printed Circuit yes yes
Voltage Regulator yes yes
Electronic Level Control Compressors yes yes
Pneumatic Suspension Pumps yes yes
Moisture Control Sensors yes yes
Keyless Entry System yes yes
Factory Installed Anti Theft System yes yes
Power Seat Motors yes yes
Power Sun Roof Motors yes yes
Convertible Top Motors yes yes
Computerized Timing Controllers yes yes
Electric Driver Information Displays yes yes
Turn Signal Switch yes yes
Ignition Module yes yes
Factory Installed Thermometer no yes
Factory Installed Compasses no yes
Fuel Sending Unit yes yes
Anti Detonation Sensors yes yes
Cruise Control Components yes yes
All Manually Operated Switches yes yes
Power Door Locks yes yes
Electric Window Defrosters yes yes
Electronic Spark Controllers yes yes
Brake Switch yes yes
Hazard Switch yes yes
Horns and Horn Buttons yes yes
Head Lamp Switch yes yes
Oxygen Sensor optional yes
Suspension WA Platinum Integrity Automotive Protection (IAP) OEM
Steering Knuckles yes yes
King Pins and Bushings yes yes
Spindles and Spindle Supports yes yes
Leaf Springs yes yes
Wheel Bearings yes yes
Ball Joints yes yes
Control Arm Shafts and Bushings yes yes
Strut Bar and Bushings no yes
Torsion Bars yes yes
Coil Springs yes yes
Radius Bar and Bushings no yes
Stabilizer Bar and Bushing yes yes
Spring Shackles and Shackle bushings no yes
Control Arms yes yes
Steering WA Platinum Integrity Automotive Protection (IAP) OEM
Tie Rods yes yes
Tie Rod Ends yes yes
Power Steering Cooler Lines yes no
Main and Intermediate Shafts yes yes
Steering Couplings yes yes
Power Steering Cooler yes yes
Pitman Arm yes yes
Idler Arm yes yes
Link and Control Valves yes yes
Pivot Joints no yes
Drag Link yes yes
Power Cylinder Assembly yes yes
Power Steering Control Valve yes yes
Air Conditioning WA Platinum Integrity Automotive Protection (IAP) OEM
AC Condenser yes yes
AC Compressor Clutch Coils and Pulleys yes yes
Evaporator Core yes yes
The Accumulator yes yes
Serpentine Belt Tensioner yes yes
Idler Pulley and Bearing yes yes
AC Ducts and Outlet Hoses yes yes
AC Compressor Internals yes yes
Expansion Valve yes yes
Hi/Low Cut off Switch yes yes
POA Valve yes yes
Temperature Control Programmer yes yes
AC Power Module yes yes
Blower Motor yes yes
Orifice Tube yes yes
HI/LOW pressure lines yes yes
Receiver/Dryer yes yes
Brakes WA Platinum Integrity Automotive Protection (IAP) OEM
Drum Brake Wheel Cylinders yes yes
Disc Brake Calipers yes yes
Combination Valve (Proportioning Valve) yes yes
Brake Hardware (springs, retainers, clips, self activators yes yes
Self Adjusters yes yes
Parking Brake Linkages yes yes
Vacuum Assist Booster yes yes
Brake Lines and Hardware yes yes
Power Assist Booster yes yes
Backing Plate yes yes
ABS Components yes yes
ABS Master Cylinders yes yes
Cooling System WA Platinum Integrity Automotive Protection (IAP) OEM
Heater Core no yes
Thermostat no yes
Radiator yes yes
Coolant Sensors no yes
Heater Control Valve no yes
Coolant Fan yes yes
Fuel Delivery WA Platinum Integrity Automotive Protection (IAP) OEM
Fuel Tank yes yes
Fuel Pressure Regulator yes yes
Fuel Injection Metering Pump no yes
Fuel Rail no yes
Sensors no yes
Fuel Injection Pulsators no yes
Fuel Distributors no yes
IAC Motor no yes
Fuel Lines yes yes
Emissions WA Platinum Integrity Automotive Protection (IAP) OEM
Air Control Valve optional yes
Air Idle Vaccum Valve optional yes
Air Supply Valve, hose and tube optional yes
Air Check valve assembly optional yes
Barometric Pressure Sensor optional yes
ECC relay assembly optional yes
EGR control valve optional yes
EGR pressure sensor optional yes
EGR regulator optional yes
EGR valve adapter optional yes
EVAP vapor storage canister optional yes
Idler Air Control Valve optional yes
Vacuum Restrictor optional yes
Flywheel yes yes
All Pulleys yes no
Timing Belt yes yes
Piston Pins yes yes
Vacuum Pump no yes
Push Rods yes yes
Oil Pump yes yes
CV Joints yes yes
Distributor yes yes
Gauges yes yes
Ball Joints yes yes
Tie Rods yes yes
Pitman Arm yes yes
Idler Arm yes yes
Pivot Joints no yes
Drag Link yes yes
POA Valve yes yes
Heater Core no yes
Thermostat no yes
Radiator yes yes
Coolant Fan yes yes
Fuel Tank yes yes
Fuel Rail no yes
Sensors no yes
IAC Motor no yes
Fuel Lines yes yes
I've got an extended warranty for my Accord, which is '05 and only got 35k miles. A warranty at warrantydirect.com for 5 yrs / up to 125k miles was only $1,600 with $50 deductible, and that's bumper to bumper, not just powertrain. The quote I got for them for my RX was around $1,800 for powertrain only until 100k miles, and i think it's not worth it. My thinking is that neither the engine nor the transmission are likely to give before 125k on the RX, and anything else like starter, alternator, etc. I can fix myself possibly lot cheaper than $1,800.
Don't waste your money:
You should be able to get it a lot cheaper than $2000,
Extended warranty companies go bust every day,
Your 2003 RX300 has no major failure items (like the 1999-2001 transmission),
You can get an awful lot of repairs done for $2000!
If you do go for it, look for what is NOT covered, not what is covered - you may be surprised!
viprez586
IS F (2008-2014)
05-05-18 03:13 PM
lserlohn
RX - 1st Gen (1999-2003)
04-28-11 05:49 AM
2001, automotive, es300, extended, iap, integrity, is, oem, orifice, proportioning, protection, rx300, tube, valve, warranty
