Has your RX 300 surpassed 200k miles??
Old 09-17-12, 06:01 PM
  #46
Bobster999
Bobster999's Avatar
Originally Posted by toyo
352K on her. Trans rebuilt at 190K. Only repair I have to do on the engine was valve cover gaskets. It even has the original ignition coils! She just won't die
WOW...
Old 09-19-12, 11:15 AM
  #47
lexus114
lexus114's Avatar
What motor oil do you use?
Old 09-19-12, 11:20 AM
  #48
dbui
dbui's Avatar
Nice! my RX300 01 oil change today at 171171k everything original, I' m getting ready to do the 2 time around timing belts replace and tune up when it reaches 200k the magic numbers lol!!!! Sweet RX300 Lexus
Old 09-20-12, 12:03 PM
  #49
JJ00rx300
JJ00rx300's Avatar
Default knock sensor
Neither did my mechanic. He was positive that wasn't the issue but I assured him it was based off of what my trans. specialist said and a forum on here that had about a handful of rx owners with the same problem/solution. It's because the ecu gets a bad reading from the sensor which then affects the transmission control from the ecu. Weird, I know. Hardly makes sense but proven true
Old 09-20-12, 02:42 PM
  #50
salimshah
salimshah's Avatar
Received 1,007 Likes on 910 Posts
Sorry JJ00rx300 ,,, I am quoting you you bring attention to CEL ...
Knock-sensor are just one of the reason why the ecu would lock out overdrive. If it is emission related lock-out (like the the signal from bad knock sensors) there will be a CEL. With the CEL on, have that diagnosed before trying to find out what else is wrong.
Salim
Old 09-25-12, 06:27 PM
  #51
JJ00rx300
JJ00rx300's Avatar
Default knock sensors
No offense salim but its common sense to run a diagnostic but if you're dealing with someone who is unfamiliar with this problem (which probably consists of about 95 percent of non specialized mechanics, including dealership) you can plan on spending hundreds if not thousands (say for a new or rebuilt transmission) on unnecessary replacements. Which dealers love to do!!
Old 09-25-12, 07:18 PM
  #52
salimshah
salimshah's Avatar
None taken.
Knock sensor repair (labor + parts) is not cheap ... I am estimating about $1200 at the dealership. I hijacked your post, to make a point that rely on CEL + codes to diagnose the knock-sensor issue.
There can be dishonest mechanics and dealerships.
My personal experience with local Lexus dealership has been positive. I have seen the staff go out of the way to help other customers. Granted the service is not cheap, but I have no reason to think they indulge in deceptive practices. At times they might replace a module instead of a switch and that is because how the part is stocked and for some other times extra things eliminates return service [rotor surfacing].
Salim
disclaimer: The above is my personal experience. The free snack bar (which is available to all customers) has not influenced me.
Old 09-27-12, 10:33 AM
  #53
gsenthil
gsenthil's Avatar
205k on mine. Daily driver for the last 11 years (added another RX to the stable this month). Am one of the lucky ones in 2001 with the transmission issue- was fixed at 120k miles in 2008 has been running fine since. Other things that have gone wrong
Door lock actuator @ 90k and 180k
Air Mix servo at 200k
Other issues that I will live with
Carpets are kinda worn out at the bottom
Driver seat edge has a small tear
Rear hatch opens slowly
Engine mounts need to be replaced- there is a vibration at idle (at stoplights etc) which is annoying but goes away when being driven. It is a $50 part that will cost 1500 in labor
Maintenance= Oil change every 5k until 50k then every 7500 until 180 and every 10k afterwards. ALWAYS Mobil 1 EP done at Toyota (cost = $15ish labor)
30k/60k intervals done per factory (not dealer) spec at Toyota/Lexus
90k intervals done at independant mechanic.
Buy most parts myself. My 90k costs ~1k (incl pads/rotors/plugs etc)
Old 11-03-12, 04:03 PM
  #54
Leines
Leines's Avatar
I have 186,000 on my 99rx. Or 300,dismiss kms here in Canada
Old 11-18-12, 12:01 PM
  #55
colenzae
colenzae's Avatar
Will pass 200,000 miles this week. 2002 AWD original owner. Replaced timing belt and spark plugs once.
Old 11-22-12, 11:46 AM
  #56
TCAL
TCAL's Avatar
Second owner. Original engine and transmission. 210K. Repaired strut plate design, AF ratio sendors, Front Manifold now the engine has suspected gel issue.
Old 11-22-12, 06:14 PM
  #57
richee3
richee3's Avatar
I just picked up an RX last week. I'm the second owner, 211k, all original. It needs three lock actuators and both valve cover gaskets leak. Otherwise, it's all good. It'll be getting the timing belt and the works soon, but I'm ironing out the little details for now.
Old 11-25-12, 05:13 AM
  #58
scratchwin
scratchwin's Avatar
yes , my RX 300 is 12 years old. Bought it new. No problems
Originally Posted by jcjr
How may of you have more than 200K on your RX 300???..original engine?
original transmisssion?
What year is it??
Thanks...
Old 12-28-12, 01:13 PM
  #59
coachdon56
coachdon56's Avatar
2000 rx300 just went over 205k......tranny rebuilt @ 175K due to moron mechanic not putting in enough at fluid when he changed filter and pan gasket...cost 2475 to rebuild...otherwise all normal maint. issues...
Old 12-28-12, 02:28 PM
  #60
hypervish
hypervish's Avatar
Welcome to Club Lexus!
Quick Reply: Has your RX 300 surpassed 200k miles??
