What causes these codes? P0440, P0441, P0446
Old 04-24-07, 07:19 PM
nc-longhor
nc-longhor's Avatar
Default What causes these codes? P0440, P0441, P0446
I just received p0440, p0441, and p0446 codes again, and the VSC, Trac off, and check engine lights are on. I have cleared the codes and they stay off for several days/weeks and several hundred miles. I believe they have to do with the emission control module (according to Auto Zone), but I don't know what to do to keep them off. I have been very careful to only fill the gas tank to the automatic shutoff and add no extra gas, and to screw the gas cap on tightly, usually tightening the cap into the clicking noise three times. I have a CD service manual, but cannot find these codes in the manual. Can anyone give me additional things to check and fix. Thanks in advance for your help.
Old 04-24-07, 08:11 PM
Lexmex
Lexmex's Avatar
P0440- Evaporative Emission Control System Malfunction
(caused by the fuel trank pressure being equivalent to atmospheric pressure after 20 minutes with vehicle on)
Areas to check:
Vapor pressure sensor
fuel cap
vacuum hose
fuel tank
charcoal canister
P0441 Evaporative Emission Control System, Incorrect Purge Flow
P0446 " Vent Control Malfunction
these 2 codes usually accompany the P0440 and they have similar trouble areas
getitright (09-23-22)
Old 04-25-07, 05:12 PM
mikey00
mikey00's Avatar
These are the 3 codes you get when the evap hose is disconnected behind the air filter box.
LegoGuy (04-10-17)
Old 05-06-09, 04:51 PM
m1tk4
m1tk4's Avatar
That's exactly what it was in my case. THANKS!!!!
Old 05-23-09, 11:11 AM
Heepspo
Heepspo's Avatar
Me toooo! If this works I owe you guys big time!
SO I reconnected the hose then I disconnected the battery for a bit and will reconnect later. I've heard that's a good thing to do what getting your codes reset. Yes? No?
Does this sound like the proper steps to take getting things set back to normal, if in fact this was the only problem?
Thanks in advance! The info on this site is outstanding!
Old 05-23-09, 11:42 AM
lexus114
lexus114's Avatar
it is always best to clear the ecm via a scanner,but doing the battery thing will do.
Old 05-27-09, 08:18 PM
Heepspo
Heepspo's Avatar
Passed emissions today!
Thanks so much for the information!
Old 05-29-09, 04:37 PM
Brucesdeli
Brucesdeli's Avatar
Hello,
It could be oxygen sensor(s) need to be replace.
you can get this replacement part(s) thru online autopart stores.
It cost about $ 120-145.00 including shipping & handling and the oxygen sensor is located under the driverside seat, you may have to use sharp blade to cut carpet to access and follow the wire(4wires cable wrap around black tube) to outside of the car.
Good Luck!
*p.s. after replacing with new oxygen sensor you have to reset the mother board computer on a car, It will be go out buy one of the CanOBD2 CodeReader made by Innova, It is really worth the money. It costs about $ 100-150.00 depend on autoparts store or look for sales like kragens auto part.
Good Luck again,
Bruce
Old 09-13-09, 10:01 AM
mikemacch
mikemacch's Avatar
Thanks Mikey just replaced the Knock Sensors and lo and behold the hose is disconnected behind the air filter box. Thanks
Old 06-12-14, 11:24 AM
kurdeem
kurdeem's Avatar
got these codes recently including the p0442 hopefully your advice works... finger crossed
Old 03-10-15, 09:15 AM
howdybob22
howdybob22's Avatar
Did it work for you? My car also just threw the Check engine, vsc, and trac off. I'll be heading to autozone today to pull the code. Hopefully, it's the same reconnect the hose and disconnect the battery for a while then reconnect up.
Old 08-04-15, 11:13 AM
Lexibug
Lexibug's Avatar
Thank you! Sure enough, it was disconnected! You probably saved this girl a lot of money!
Old 09-09-15, 07:25 AM
ctaylor11
ctaylor11's Avatar
I'm having this same issue. Also, I noticed that my car sounds like it's going to completely shut off. I took my IS300 to the dealer, and they said I had a weak battery. So I replaced it and when I was heading home, it sounded like it was going to stall. I went back and the diagnostics read P0440, P0441, and P0446. The check engine light is on, and Trac Off light is blinking. I'll check the hose and see if that works. Thank you!
Old 10-21-15, 03:18 PM
mmatheny
mmatheny's Avatar
Same with me!! Cleaned the throttle body and forgot to hook that hose up! Thanx a bunch!
Old 03-14-17, 01:04 PM
ML888
ML888's Avatar
Smile RX 300 Po440, P0446
Thanks For the Info Very Helpful
Quick Reply: What causes these codes? P0440, P0441, P0446
