O2 sensor Bank1 Sensor1 - Best Price
My Check Engine light came on today so I hooked up my PC and it read:
--P0125 Insufficient Coolant Temperature for Closed Loop Fuel Control
--P1133 Sensor Circuit Slow Response (Bank 1 Sensor 1)
--P1135 Sensor Heater Circuit (Bank 1 Sensor 1)
I cleared the Check Engine light and about a few minutes later the following came up:
--P1130 O2 Sensor Circuit (Bank 1 Sensor 1)
I reset it again and I haven't gone anywhere yet, but I'll read it again when the light comes back on.
In any case, it seems that the O2 sensor in Bank 1 Sensor 1 is bad.
Does anyone know the part # for this? and where is a good place to get this.
thanks,
tom
thanks,
tom
I found a few different O2 sensors. on Advance Auto Parts website:
Which one do I need? is Bank 1 Sensor 1 the Downstream or Upstream?
The Bosch is twice the money and has a 1 year Warranty and the Beck/Arnley has a Lifetime warranty for half the price.
Bosch 13338
OE Type; 4 Wire; Heated; Downstream Sensor; Check/Replace Interval 100 K Miles
1 Year Replacement Warranty Ships in 1 day
Weight: 0.3 lbs. $222.88
Bosch 13333
OE Type; 4 Wire; Wideband; Upstream Sensor; Two required; Check/Replace Interval 100 K Miles
Weight: 0.3 lbs. $328.88 NAPA has this one for $200
Beck/Arnley 1568401 See image and details for this item
Repl Type Oxygen Sensor: Flange Type
Lifetime Limited Warranty Ships in 1 day
Weight: 0.3 lbs. $118.88
Beck/Arnley 1568400 See image and details for this item
Univ Type Oxygen Sensor: Screw Type
Weight: 4.1 lbs. $93.48
Bosch 13338
Bosch 13333
I'm about to change out the same sensor,
This is the one you need for Bank 1 Sensor 1 (UPSTREAM)
Bosch 13333
Bosch 13333
Bank1 sensor1 and bank2 sensor one are the same thing (thank you lord)
bank1 is the rearward bank, bank2 is front most.
Toyota/Lexus part# 89467-48011
Lexus list price ~$255.00
