99 RX300 Tow Wiring Conclusion
I read several of the forums about issues with different wiring solutions for towing. Great information...but now I am in overload without the one best solution.
Here is my situation and I would appreciate anyones feedback that has lived the solution.
99 RX300 w/ towing prep package
Getting a hitch from Hidden Hitch
Wanting to tow a 5x8 U-haul trailer
What do I need to wire up and where do I get it?
Thanks for your help!
As for a wiring solution, you'd probly need the 08921-48051 Wiring harness from lexus.
99 RX300 Wiring Option
Does this kit from etrailer look as though it would do the job?
http://www.etrailer.com/Merchant2/me...Category_Code=
Plug-N-Tow™ Wiring Connectors provide a no-hassle, quick and easy way to wire your vehicle.
Fits Toyota Highlander without the tow package.
Each vehicle specific connector is pre-wired and uses original OEM connectors for water tight protection, a guaranteed fit, and a great look
No cutting or taping
16 gauge wire
4-Pole connector includes dust cap
Easy to follow instructions with pictures are included
Each kit includes everything needed to complete a 4-wire flat installation
Kit includes wire, fuse and connectors necessary for power supply hook-up at the battery
Powered converter with circuit protection is included in a weatherproof double-molded design
Circuit Protection guards the tow vehicle and the converter itself from trailer shorts
Max Draw: 8 Amps
Can be used with 5-pole, 6-pole or 7-pole adapters.
Plug-N-Tow™ Wiring Connector plugs in behind each tail light on the Highlander.
16 gauge wire
Max Draw: 8 Amps
