Clock Did Not Set DST
2016 RX 350. Time zone is correct. Daylight Savings Time is set to AUTO. Auto Adjust by GPS is ON. The clocks, analogue and digital, did not change for DST.
What am I missing?
Thanks!
What am I missing?
Thanks!
You need to go to "Settings" on the screen and select "Standard" time......
See pg 61 of Owner's Navigation Manual................
1 Display the “General Settings” screen. (→P. 59) 2 Select “Clock”. 3 Select the items to be set. ■SETTING THE TIME ZONE 1 Select “Time Zone”. 2 Select the desired time zone. zIf “Other” is selected, the zone can be adjusted manually. Select “+” or “-” to adjust the time zone. ■ MANUAL CLOCK SETTING 1 Select the desired item. CLOCK SETTINGS Used for changing the time zone and setting of daylight saving time and automatic time adjustment on/off. No. Function Select to change the time zone. (→P. 61) Select to set daylight saving time on/ off. Select to set automatic adjustment of the clock by GPS on/off. When set to on, the system will automatically adjust the clock to the current position’s time zone when the vehicle moves to a different time zone. When set to off, the clock can be manually adjusted
On a recent trip, I was informed by the Nav Screen that I was crossing the "Time Zone" from Mountain to Central and asked me if I wanted to change the two clocks mounted in the car? I selected "Yes" and both clocks went to the new time. Not as easy for DLST. After two hours of driving on the interstate, I got a note on the readout in the dash, asking if I wanted to stop for Coffee???
If you set everything auto with correct time zone it should change automatically when time signal is received at midnight. If you are missing signal due to your location or car is parked inside your garage it won't happen. I park in the garage. I just manually set it back. We have many radio time controlled watches, clocks in the house. Ones
in the basement never switch time. All watches have to be placed near the South facing windows just for one night.
If you don't get WWV signal, it'll never change time. It does not have to be on the day of change. Any time after that if signal is picked up, the tiem will corecctly set. Once O sat up watching the time change via radio signal. All the computers, TV cable box, smart phones changed. The vehicle should be in a spot where it can receive decent signal. Manually setting it takes less than a min.
clock auto reset/daylight savings time
Hi all,
I read that if I had navigation on my RX it would automatically reset the time for DST; mine did not, is there something I need to do to enable?
Thanks
Thanks
