Navigation screen not working, flashes pink screen every 12 seconds
ok mine was fine at 10:35-10:47am pst then it went dead and started this pink thing since. Came here to find this thread. Great.
EDIT
I just called my dealer and they said this is affecting all the new Lexus with Enform and the sattelite is rebooting itself. He said to give it a day then check it tomorrow.
EDIT
EDIT
EDIT
Vehicle may die after 2-3 seconds. If so, restart vehicle again.
Verify System Reloading screen, keep vehicle on until completely rebooted.
Everybody, if you can, do this. It worked.
I just tried it again @ 12:20pm and it's still fine. Maybe after running for a time it will go down again? I will find out when I go out and it's on for a while-but at least for now, the reset worked on mine.
10mm wrench on negative terminal. Loosen a few turns and pry off terminal from battery post.
Wait 5-10 minutes
Tighten terminal on post, start vehicle. Verify "System Loading" screen
Note: This is a very temporary fix.
Wait 5-10 minutes
You seem to have some inside information on this issue, Lexus61030.
Do you know what -- if anything -- is Lexus doing to ensure that something like this doesn't happen again? Will they release a root cause to owners?
If I get any new information, I'll let you guys know. I'm a service adviser at a Lexus dealership... You can imagine how my day has been.
Is it easy to find the terminal and disconnect it? Trying to find a video or some kind of illustrations of power cycling the navigation but out of luck. Don't think my wife will be comfortable doing this unless it's easy.
