Parking assist dynamic gridlines not showing
Even when this setting is chosen, I sometimes get the yellow guidelines and sometimes I do not. Like this morning: backing out of the garage; no guidelines. 30 minutes later, having driven to work, guidelines appear. I did not change the settings.
Could this be a function of the car warming up??? I assume I am headed to the dealer...
Yesterday, at least, it was quite consistent: no guidelines when first starting car; guidelines 30 minutes later.
Will keep an eye on it and head to dealer when convenient.
I'll post back if anything interesting turns up.
Thanks!
Thanks!
I think I have an answer and the solution.
Another problem, that I noticed since picking up the car, was that it was sometimes difficult to start: would crank, but not "catch." After a near failure-to-start experience, I took to the dealer and left it for a day.
The diagnosis for both the starting problem AND the dynamic (yellow) guidelines was a defective battery! They put in a new battery, and both problems are solved.
Interesting... thought people might want to know.
The following 2 users liked this post by greyguy:
GSFRX350 (12-26-18),
JacobPatri (08-06-22)
Please tell me how you got the park assist to appear in the right third of the screen? I turned the display on and off through the settings but couldn't get it to look like this. Currently I have to look at the speedometer for the park assist and the nav for the gridlines and panoramic view.
I posted my understanding of this on Jan 22. Here's how I think it works:
The Settings -> Vehicle -> LEXUS parking assist. -> Display Off button only serves to turn on/off the display on the right side of the Nav screen of what what the sensors think you are close to. It is not the easiest image to interpret; pushing it only highlights/unhighlights the button.
But, I'm pretty sure this is how to turn on the display on the right panel, at least on my 2016 Rx350.
Hope it helps.
Hope it helps.
Hope it helps.
Hope it helps.
2017 Lexus RX Parking lines
Hi guys,
I just joined the Lexus club! I got the 2017 RX (Platinum Package). I have an issue with my parking assist. The yellow lines that move with the steering wheel do not appear. I tried the 3 different options in the settings when it's set on R but it still won't appear. I only get the red line, red and blue lines or only blue lines that are all static. Why do I not have it? It's kinda frustrating!
Help please.
Help please.
https://www.clublexus.com/forums/rx-...t-showing.html
Get used to all the features on your new rx. There are so many features it's a little frustrating figuring them out. Wait till you hit a button by mistake and can't figure out how to get back. Good luck. This is a good place to get info, enjoy!
Hi guys,
Help please.
Help please.
With car engine on try turning the steering wheel all the way to the left then all the way to the right. If the car ran out of battery it loses the lines and you need to reset the limit by doing the above.
The following 2 users liked this post by SirKong:
crf3973 (05-12-21),
Thanks. I tried that but it didn't work. It's a new car. I'm assuming the battery is still in good shape. I have a little exclamation mark next to the gridline option. It appears when I choose the second option where the yellow lines should be appearing. I'll try to take a picture later. It's so annoying! I'll try to look in the manual for any parking assist errors.
Mine was new too. Had a defective battery got it replaced. I think the exclamation mark means that calibration is needed.
No predictive lines anymore
Hopefully someone knows what to do!
I haven't driven my car in 2-3 days. When I went to start it the car seemed like it stalled and had a very difficult time cranking. I assumed that the battery is dying or died and came back to life on its own. The car is about 2.5 years old.
A few settings had been reset such as the customize feature for the chassis etc.
The main issue I am having now is that the predictive yellow lines that show your path is now completey gone. All it shows is a small triangle explanation mark on the lower right corner. I have the pano view monitor as well.
Not sure what's going on. I drove it a few times as well as turned the engine on/off 3-4 times and it still isn't showing.
Any advice? thanks!
Any advice? thanks!
Lol. This just happened to me after 2.5 years of ownership. No issues at all before then.
Now I get bad cold crank starts and I've lost the yellow gridlines with a nice grey triangle explanation mark.
Going to the dealer to see if I can get a free battery
Try this:
Press the “MENU” button on the Lexus Display Audio controller/Remote
touch, and then select Settings icon on the screen.
Select “Vehicle”, and then select “Backup Camera Guide Line Settings” on
the screen.
the screen.
