Ebay LED interior 2013 RX350 $6.95 for the set + install tips!!
Hi Guys,
I am new to this forum not to the site as I am a long time member coming from the second Gen IS ans RX forums.
Wife traded her 08 RX350 for a 2013 RX350 fully loaded and decided to start modding it for her. I just did the interior led swap.
I purchased this 13 pcs set from eBay for $6.95
http://www.ebay.com/itm/361422971373
It arrived pretty quick I highly recommend the seller. Went to town with no instructions on how to do it as I have done these on several other Lexus vehicles. Everything was smooth sailing except the rear passenger side dome, what a pita it is to remove that cover! I used a shoppers card to separate the cover a bit from the housing and using a small pick tool (hook type) I pull the cover gently but with force until it gave way and I was able to pull it away entirely by hand. I thought I was going to break the cover as it is really hard to pull from the tabs. Just when you thought pulling the cover was bad enough the next issue is removing the bulb itself, I had to use needle nose pliers to remove it. Space is very limited around the bulb so to replace it with LED you again have to hold the bulb with the needle nose pliers using the tip of it and force the bulb in. Make sure of the polarity is right before installing the new bulb. Front dome is not as bad fact I used a credit card to remove the cover, all you have to do is wiggle the card once it is wedged around the cover and it pulls fairly easy.
Sorry I don't have pics but trust me reading this makes your job so much easier and that is why I wanted to share this.
Next will be LED fogs, Cree LED reverse bulbs. Have to order these.....
Pick tools used
As with any do it yourself programs do all of this at your own risk!! I am not responsible for anything you break or damage. My tip is to be gentle when using the metal picks. I picked between the credit card and the cover never touching the cover base!
Happy modding!
Pick tools used
Happy modding!
Link fixed
I just picked up a 2011 RX 350 and was thinking of changing all the lights and was looking for an alternative to vleds as the other thread said that it cost $200 usd for all the leds.
your link seems very decent, do you have any pictures of it? i was looking at some as well and found this
http://www.ebay.com/itm/19x-White-Interior-LED-Lights-Package-Kit-for-2010-2015-RX350-RX450H-TOOL-/181874043299?fits=Year%3A2011%7CMake%3ALexus%7CModel%3ARX350%7CSubmodel%3ABase%7CEngine+-+Liter_Display%3A3.5L&hash=item2a5889a9a3:g:~SEAAOSwIgNXkQWL&vxp=mtr
http://www.ebay.com/itm/12PCS-White-LED-Lights-Interior-Package-for-T10-31mm-Map-Dome-License-Plate-/361422387695?fits=Year%3A2010%7CMake%3ALexus%7CModel%3ARX350%7CEngine+-+Liter_Display%3A3.5L&hash=item542673f9ef:g:FAoAAOSwhcJWOOFR&vxp=mtr
i dont know how well they compare to urs and vleds.
i was also planning to change the H11 fog light to this http://www.ebay.com/itm/H11-6000K-2016-120W-12000LM-4-Sides-LED-Headlight-Kit-Low-Beam-Bulbs-High-Power-/262325354149?fits=Year%3A2011%7CMake%3ALexus%7CModel%3ARX350%7CSubmodel%3ABase%7CEngine+-+Liter_Display%3A3.5L&hash=item3d13cf3ea5:g:Cf0AAOSwWfFXkclY&vxp=mtr
and dang . it sucks for guys here in canada. it cost more to ship than the acutal value of the led T_T US $13.46 for shipping when the leds cost
US $6.94 T__T
Thanks.
US $6.94 T__T
US $6.94 T__T
I can tell you right now that I have purchased these before from this seller for my IS350 and the 08 RX350 we traded and have them for several years with no issues at all. still as bright as day one. All bulbs are sensitive to handling and dirt you just have to be careful.
I know there are issues with household LED bulbs and dimmers and I know that our 2011 RX dims/ramps automatically.
Did both of your previous vehicles have interior lights that automatically faded/dimmed to [OFF] and ramped up to [ON] every time someone opened/closed the door?
