HID Bulb Replacement Instruction
Hello,
Just wondering does anyone know how to replace the HID light bulbs for 2013 RX 350? I want to replace them with the 8000K but having hard time to find any information or instruction. Any help would be greatly appreciated.
Welcome to CL, You really should actually use the search feature as it works really well. This has been covered. See this link where I posted a response with links to how to do it. It is about the same in most Lexus models.
https://www.clublexus.com/forums/rx-...-hid-bulb.html
Thank you for your reply. I did use the search feature on this forum but find nothing. The link you provided is not the instruction to remove 2013 RX as the housing on this year is different than the link. That's the reason why I asked for help. Any other idea? Thanks!
Look in the ES, or GS forums. I suspect they may be the same. Also try the Highlander forum at www.Toyotanation.com
Also do a Youtube search. Most HID assemblies are pretty similar among models of the same manufacturer. You just have to generalize from one to the other.
There is a lighting forum section
https://www.clublexus.com/forums/lighting-128/
cvuplay
RX - 3rd Gen (2010-2015)
09-19-22 01:10 PM
