Force the HVAC to stay on fresh?
S there anyway to have the HVAC stay on fresh, if you don't have the luxury package? It seems the system favors the recycle mode and things start to smell like wet dog if I don't constantly remember to keep it on fresh
Thanks.
Thanks.
My Audi has that option, but the RX doesn't.
You have to press the Recirc button manually each time you see it turn on.
Everyone has smelly AC - compliments of AC running all the time. An old school trick is to turn it off occasionally to let the mold burn off. There is no button this time - only a menu option. Obviously, this is a no-concern during winter months for us Northern folks.
Or you can take it to the dealer and have them spray the inlet with bleach.
My Audi has that option, but the RX doesn't. You have to press the Recirc button manually each time you see it turn on. Everyone has smelly AC - compliments of AC running all the time. An old school trick is to turn it off occasionally to let the mold burn off. There is no button this time - only a menu option. Obviously, this is a no-concern during winter months for us Northern folks. Or you can take it to the dealer and have them spray the inlet with bleach.
Removing AC button was their next great idea.
As a Mazda exec stated, common sense is not so common in the Auto industry.
Don't know how much of this is BS, but the dealership told me Toyota programmed all of their cars to default to recycle "stink mode" to get better fuel ratings and satisfy the EPA! I guess it's why they removed the auto mode from non luxury packaged models. Either way it bites and I guess like I got used to clicking accept with the navi on the old car, every time I got in it, I get to click fresh now or get hit by stench midway to my destination.
This topic regarding TOYOTA/LEXUS A/C odor has been covered quite often over the years in the CLUBLEXUS forums.
If your system is starting to smell like "wet dog" as you put it, suggest getting the TOYOTA A/C REFRESH KIT ( 00289-ACRKT )
It's 2 cans.
One is a foaming aerosol which you shoot up into the evaporator drain (where the water-condensation comes out) under the car.
It cleans the coils where the mold & bacteria tend to build up due to the moisture and darkness.
The foam eventually starts to break down after a few minutes and will drain back out through the same hole.
The other can is an aerosol to spray into the vent intake at the base of the windshield (near the wipers).
I've used it and it works fairly well.
Costs around $20.
It's 2 cans.
Costs around $20.
This topic regarding TOYOTA/LEXUS A/C odor has been covered quite often over the years in the CLUBLEXUS forums. If your system is starting to smell like "wet dog" as you put it, suggest getting the TOYOTA A/C REFRESH KIT ( 00289-ACRKT ) It's 2 cans. One is a foaming aerosol which you shoot up into the evaporator drain (where the water-condensation comes out) under the car. It cleans the coils where the mold & bacteria tend to build up due to the moisture and darkness. The foam eventually starts to break down after a few minutes and will drain back out through the same hole. The other can is an aerosol to spray into the vent intake at the base of the windshield (near the wipers). I've used it and it works fairly well. Costs around $20.
Eagle1xOne
08-12-18 02:36 PM
