New tires and brakes on a 2013 CPO RX350... too good to be true?
Old 09-22-15, 11:34 AM
raylor
raylor's Avatar
Default New tires and brakes on a 2013 CPO RX350... too good to be true?
I have noticed few CPOs come with new tires and brakes. Let's face it, if a dealer can get away without the additional cost, they will! I found one at approximately 45,000 miles with new brake pads, rotors, and tires. From the carfax:
"Four wheel alignment performed
Four tires balanced
Four tires mounted and balanced
Front brake rotor(s) replaced
Front brake pads replaced
Rear brake pads replaced
Rear brake rotor(s) replaced
Tire(s) replaced"
When I ask is this too good to be true, what I mean is would this suggest something about this particular vehicle tends to wear out the brakes and tires? Something to be concerned about or a virtue since tires and brakes are pretty pricey and would be needed at some point anyway. Thanks!
Old 09-22-15, 11:51 AM
FLYCT
FLYCT's Avatar
Not unusual. For a car to be certified the tires and brake linings must meet minimum measurments. Also battery is load tested. If either of the above don't meet requirements they need to be replaced.
I just traded in my CT200h with 24,000 miles. Last time I had the tires balanced and rotated about 3 months ago at a tire place they measured 50% remaining tread. 3 months later Lexus replaced the tires and 12 volt battery in order to certify it. I never had an issue with the battery.
Old 09-22-15, 11:54 AM
FLYCT
FLYCT's Avatar
To add. You can ask for and will receive the certification inspection sheet that lists pad thickness, every rotor measurement and every tire tread depth.
Old 09-23-15, 12:45 AM
sdwtchlvr
sdwtchlvr's Avatar
What flyct said...Lexus can't/won't certify it with worn tires and brakes. Though I'm surprised they replaced the roots instead of resurfacing them.
Old 09-23-15, 08:22 AM
FLYCT
FLYCT's Avatar
Originally Posted by sdwtchlvr
What flyct said...Lexus can't/won't certify it with worn tires and brakes. Though I'm surprised they replaced the rotors instead of resurfacing them.
They probably didn't have enough meat left on them to turn.
The norm is when replacing brake pads to turn rotors. Before turning them they measure them to make sure they have enough "meat" and can be turned and still be at the legal minimum safe working thickness.
Koz
GX - 2nd Gen (2010-2023)
201
09-22-21 01:21 PM
pman6
04-14-19 04:34 PM
modthispny
11-12-14 08:35 PM
gappell
ES - 5th Gen (2007-2012)
06-30-09 09:02 PM
sirkfc
Suspension and Brakes
12-28-06 06:10 PM
Quick Reply: New tires and brakes on a 2013 CPO RX350... too good to be true?
