Conventional vs. Synthetic Oil
Old 06-10-14, 12:20 PM
jdshaw
jdshaw's Avatar
Originally Posted by LeoDLion
Are you saying the newer RX models can run on regular gas? My 2011 is strictly premium per manual.
2013 and newer are tuned for regular gas.
Old 06-12-14, 11:18 AM
lexus114
lexus114's Avatar
my 15 runs regular gas and I am fine with that. i always used premium in my last two rx`s simply because that is what they ran the best on. but now i dont........
Old 06-12-14, 11:54 AM
Cruiter
Cruiter's Avatar
I've used Blackstone for three of my oil changes. Gives you a good feeling when you go 10k on the oil and they give it a good report
Originally Posted by fastnoypi
if you really want to get the most out of your oil, send a sample of used oil for analysis like Blackstone Labs.
You will get the breakdown of whats wearing in your engine, whether or not your oil is giving you adequate protection and a suggested oil change interval if your sample is consistent with your normal driving habits.
A standard test is around $25. Well worth the cost for piece of mind and possibly less costly maintenance down the road.
Old 06-12-14, 11:59 AM
Cruiter
Cruiter's Avatar
You're car is designed to use the 0w20w full synthetic oil. Like most manufacturers now you have a low friction engine built with higher tolerances and uses thinner synthetic oil. If you look in your owners manual, it probably reads as mine does that if that happens, change it again within 5 thousand miles with the correct grade and specs. You'll probably notice slightly less fuel economy with the thicker oil.
Originally Posted by desnard
This topic has probably been beat to death, but going through some service paperwork, I noticed that on my first 10K oil change for my 2010 RX350 the dealer used 5W30, then the next time used synthetic. Are you subject to damage of any type by bouncing back and forth between synthetic and conventional, even if you're changing the oil regularly? I now have 38K miles and car seems to be running fine, but now I'm concerned. Thanks!
Old 06-12-14, 12:38 PM
fastnoypi
fastnoypi's Avatar
please share your reports and what brand/weight oils you have used
I am very curious of wear characteristics of the 5w20 and 0w20 oils that are out there.
Old 06-12-14, 01:05 PM
markrivers
markrivers's Avatar
It started with 2012 MY.
I used to have a 2011 and i was scratching my head when the press release for the 2012 came out.
Old 06-12-14, 02:06 PM
Cruiter
Cruiter's Avatar
Except for one dealer screw up, the 0w20w Toyota oil. Works well. I'm getting most of my oil changes done at the Toyota store. It's the same oil, but they don't take as much of my money .
ajay60610
02-19-17 07:14 AM
-Future-
Maintenance
18
10-27-13 12:10 PM
krue92
IS F (2008-2014)
15
08-23-11 03:50 PM
beckysdad
RX - 3rd Gen (2010-2015)
41
03-11-10 02:51 PM
ZULU789
Performance
08-17-06 06:35 AM
Quick Reply: Conventional vs. Synthetic Oil
