2007 RX400H Tightening Axle Shaft Boot
Old 10-27-16, 07:48 AM
jpw
jpw's Avatar
Default 2007 RX400H Tightening Axle Shaft Boot
Our new-to-us RX400H is coming up in 180K miles, so we're doing the 60K mileage. I should post the estimate that the Lex dealer gave us as a quote - $970 or so with nothing major on there - mostly stuff like check this, check that. Changing oil , filter, change air and climate filters seemed to be the most difficult items, which are easy and I changed the oil/filter as soon as we bought it. Timing Belt/Water pump were done at 170K miles..
One item named "Tighten Axle Shaft Boot" is a little perplexing. I obviously know where they are, but are there specific torque settings ? I've had numerous cars/trucks with CV Boots but I've never seen tightening these as a service item - they mostly seem to have these non-adjustable metal bands fixing them to the shafts... I just replaced my Tacoma's left Axle and they had those non-adjustable bands.
Can someone who's done this comment on this procedure? Do you just see if the bolts (assuming bolts or hose clamps?) are loose and tighten them ?
I did a search here and didn't find any info on this
TIA
Old 10-27-16, 11:28 AM
Barry2522
Barry2522's Avatar
Your right they are put on with metal bands you cant tighten them . Take it to a good independent shop and save a pile of money.
Old 10-27-16, 12:11 PM
jpw
jpw's Avatar
Thanks !
Yea, I just got underneath and looked at them and they look like those un-adjustable bands.. They look OK..
I think the only thing I'll have done by the dealer is to flush the brake fluid - I'll do the rest myself..
Old 10-28-16, 06:44 AM
thomas1
thomas1's Avatar
Excellent choice...You will save hundreds.
Old 10-29-16, 06:36 AM
alchemist
alchemist's Avatar
Originally Posted by jpw
Thanks !
if it actually needs to be tightened it needs a tool like this:
http://mobiledistributorsupply.com/cv-joint-boot-pliers-1.html?gclid=CMmMzfGQgNACFYERgQodk-oKUA
Old 11-01-16, 06:22 AM
SkiMe
SkiMe's Avatar
I just added a new one. About $5 clamp at Napa, and then bought the special pliers at O'Reilly's for $9. I was able to install a new clamp from the bottom side of vehicle without removing the wheel. I like the Napa one because it was more solid and adjustable.
The tool is NOT quality but worth a shot if you only have one boot.
Old 11-07-16, 09:22 AM
jpw
jpw's Avatar
Thanks for the info guys..
Old 11-07-16, 01:59 PM
numbafree
numbafree's Avatar
Thanks !
get a power bleeder ($35 - $40) and bleed the brakes yourself, by yourself. I don't put the brake fluid in the actual power bleeder, I just stop and refill the reservoir. 10 psi is enough pressure to easily bleed the brakes. You don't even need to jack up the RX.
J295
GX - 2nd Gen (2010-2023)
04-20-18 10:25 AM
igorxx
03-28-10 04:17 PM
UncleRay
NELOC
12-17-07 11:13 AM
Colby
03-25-04 08:05 PM
jewelerz
Performance & Maintenance
11-09-03 07:08 AM
Quick Reply: 2007 RX400H Tightening Axle Shaft Boot
