90K Miles service
90K Miles service
My 2009 RX350 (2WD) is almost at 90K miles. I'm looking over 90K service and aside from replacing brake fluid, nothing is special (below):
❏ Replace engine oil and oil filter; reset reminder light
❏ Rotate tires
❏ Replace air conditioner filter
❏ Replace brake fluid
❏ Replace engine air filter
❏ Replace Smart Key battery
❏ Visually inspect brake pads and rotors
❏ Road-test vehicle
I have started to experience some hard shifting - so I'm going to do drain and fill on the transmission. For those with high mileage, any preventing maintenance I should do? Spark plugs?
I know that 2009 has a chain - so no need to for timing belt. Anything else?
I already fixed my rack and pinion leak at around 50K miles.
Thanks in advance.
❏ Rotate tires
❏ Road-test vehicle
Thanks in advance.
I would just go with the maintenance schedule for 90K miles plus the transmission service since it is shifting hard. A spark plug change is recommend at 120K, so if you don't have any starting or running problems, leave them be.
Once I touched the spark plugs, that led to eventually replacing two rear coil packs. I had no issues before but decided to change plugs at 125k. Well, once I unplugged and plugged the coil packs (and reinstalled the intake manifold), my car would not run smoothly. After trial and error, and removing/reinstalling intake manifold 3 more times, it was determined that 2 of the 3 rear coil packs decided to quite.
I replaced all 3 in rear as a precaution but what I learned.....don't wake sleeping problems if you don't have too!! Wait until 120-125k. Coil Packs are not cheap either....
mick_foley
19
10-06-08 06:10 AM
