Rear power door
Old 03-31-16, 01:14 AM
hisstojay
hisstojay's Avatar
Default Rear power door
Can anyone help out: my RX350 rear power door worked perfectly when I press both the switch button inside the car below the dash and the other switch at the rear door itself; as well as the button on the fob. Recently it stopped responding. My car electrician has checked and checked and confirmed the switches to be okay but they are not responding. I read from some thread that there's a button in the glove compartment but I can't be so sure.
Old 03-31-16, 12:22 PM
jakenbake
jakenbake's Avatar
There is a button in the glove box. Try that out. Also, if you recently had the cabin air filter replaced, they may have disconnected the harness for the button in the glove box. This happened to me at one of my services and I had to remove the glove box to plug the harness back in so my door would work.
pguerin (02-24-17)
Old 04-01-16, 12:44 AM
hisstojay
hisstojay's Avatar
Thanks. Where's the exact location of the button in the glove box? I'm gonna check it out.
Old 04-01-16, 10:46 AM
DennisMik
DennisMik's Avatar
open the glove box door and look down along the left side, maybe half way or a little more.
Old 04-02-16, 03:00 AM
hisstojay
hisstojay's Avatar
Dennis, Thanks.
Old 04-04-16, 09:47 AM
stevies30
stevies30's Avatar
So did that fix your problem?
Old 04-05-16, 02:33 AM
hisstojay
hisstojay's Avatar
Yes, problem solved and fixed....Thanks
beth303
05-17-17 01:31 PM
redtoesblue
RX - 3rd Gen (2010-2015)
12-09-15 05:29 AM
durf23112
01-04-15 10:30 AM
tombet
07-18-13 03:00 PM
CWS
07-08-13 06:14 AM
Quick Reply: Rear power door
