Automatic boot not opening or closing
Old 09-22-15, 01:15 PM
g8gsj
g8gsj's Avatar
Default Automatic boot not opening or closing
‼️Advice please‼️
I have just purchased a second hand Lexus Rx300.
The boot isn't opening or closing automatically. It just beeps twice and makes a noise like it's trying to do something but that's as much as I get ?? Anyone have any idea what is wrong? Tia
Old 09-22-15, 02:10 PM
mcomer
mcomer's Avatar
Check that the power hatch override button in the glovebox is pushed in. When it is
pressed and is extended the hatch is defeated to slow down unauthorized entry.
Old 09-22-15, 04:11 PM
g8gsj
g8gsj's Avatar
I have tried with the button in and out as I wasn't sure which way it should be and stil nothing
Old 09-22-15, 04:16 PM
litzdog911
litzdog911's Avatar
Your RX300 is a 1st generation RX, so you might want to post this question in that forum ....
https://www.clublexus.com/forums/rx-...1999-2003-182/
Or, perhaps a moderator can move it.
Old 09-22-15, 06:22 PM
mcomer
mcomer's Avatar
close the doors and lock the RX. Should work if the defeat button is press in.
Old 09-22-15, 11:04 PM
g8gsj
g8gsj's Avatar
It's a 2005 model so second generation
Old 09-22-15, 11:07 PM
litzdog911
litzdog911's Avatar
Is it an RX300 or RX350? Aren't 2005 models RX350's?
Old 09-22-15, 11:14 PM
g8gsj
g8gsj's Avatar
It's an rx300, 2005 plate
Old 09-23-15, 08:12 AM
takeshi74
takeshi74's Avatar
In the US but note g8gsj's profile.
See also:
http://blog.lexus.co.uk/history-of-the-lexus-rx/
The second-generation RX arrived in February 2003, just one month after its preview at the North American International Motor Show.
The North American market was unique in being supplied with a larger, 3.3-litre 230PS version of the original V6 engine. Because of this it was called the RX 330.
A minor model change was applied to the second-generation RX in January 2006, whereby the 3.0-litre engine was replaced with a larger yet more efficient 3.5-litre engine with Dual VVT-i. From then on the car was known as the RX 350.
I.e. 2nd gen was a 300 in the UK until the 350 was introduced for the 2006MY for both the US & UK.
Old 09-23-15, 10:41 AM
NVAKeith
NVAKeith's Avatar
When All the doors are unlocked, can you open the hatch by hand using the button on the outside of the hatch?
If not then maybe the latch is jammed or broken. There are threads around on how to remove the inner hatch panel to unlatch the door.
truenorth
01-22-16 06:03 AM
MnM24
RX - 1st Gen (1999-2003)
01-22-13 07:30 PM
txsm86
RX - 3rd Gen (2010-2015)
05-04-12 10:06 AM
IsraelRX
63
06-23-08 02:11 PM
kirk
10-22-02 05:05 PM
Quick Reply: Automatic boot not opening or closing
