RX350 control arm bushes
Old 06-22-15, 08:52 PM
addison010
addison010's Avatar
Exclamation RX350 control arm bushes
Recently got a 2007 RX350, after about a week the water pump was leaking, cost me $800 to replace a new water pump, then after a maintenance service at Ultratune, the report says this
Price for replace both front control arm bushes is around $600, I reckon a bit expensive, just wondering how much would that normally cost?
Old 06-22-15, 09:12 PM
thomas1
thomas1's Avatar
Ok first, I have a 2008 RX400h and mine are cracked also. But don't panic, this is very common on this chassis. RockAuto.com has the control arms for $49 apiece which also includes the ball joints. As you can see the major cost is the labor. two of the bolts are very difficult to get to and on my Rx requires lifting the engine while removing the motor mounts. I ordered mine and received them but have not replaced them yet. but shop around and see who gives you the best deal for the install. here is a thread on how to do it.
https://www.clublexus.com/forums/rx-...ts-w-pics.html
Old 06-23-15, 12:29 PM
LSBen
LSBen's Avatar
Mine are also cracked but my indy Toyota mechanic says not to worry about it until it fails. You should be able to feel it then.
01LS430 149k
04 RX330 AWD 196k
lance8
06-26-23 08:22 AM
eshardlow
Maintenance
02-15-18 01:12 PM
kontrazeus
09-29-17 08:33 PM
evenparr24
09-30-11 05:07 PM
Quick Reply: RX350 control arm bushes
