2004 RX 330 Transmission Problems?
Old 06-19-15, 07:45 AM
MIRX450H
MIRX450H's Avatar
Default 2004 RX 330 Transmission Problems?
I have an RX 330 with about 154K on it.
I have noticed recently that (from a stop) when I press the gas there is a slight hesitation before the car lurches forward and continues down the road. Also, in general the car doesn't seem to have the get and go it once had.
Any ideas on what I should look into to determine what might be causing this problem?
Old 06-19-15, 11:36 AM
kgog
kgog's Avatar
Have you ever done a transmission flush? If not, I would start with that.
The fluid type is Toyota IV. I just emptied mine.. took about 9L.
Old 06-20-15, 08:27 PM
LSBen
LSBen's Avatar
Sounds like clogged fuel injectors. Try a can of fuel system cleaner and clean your Mass airflow (MAF) sensor. I had good results with Berryman B-12 fuel system or injector cleaner If you've never done this before, that's the most likely culprit. Good practice would be 2 use a can with every oil change or 2x year. And clean your MAF every 30k miles when you change your air filter. They don't teach you this in the owners manual.
01 LS430 149K
04 RX330 AWD 196K
KayBahd
RX - 1st Gen (1999-2003)
09-12-16 09:39 AM
TriniLex
02-28-15 04:05 PM
kingsangle
05-27-13 11:46 PM
RA030724
07-07-05 08:16 AM
EnzoRX
16
02-28-04 12:24 PM
Quick Reply: 2004 RX 330 Transmission Problems?
