Pocket Type Cargo Net
I have a 2007 RX350. It came with a pocket type cargo net that has 2 lower clips and 2 upper elastic eyelet loops. I can't seem to figure out how it attaches. I see the pull down black anchors but I think they are for the "Spider" type cargo net, or for bungees. And even if I use the lower clips on them, where do the elastic eyelet loops get attached to. Anyone know?
I don't have an '07 or a cargo net, but I think that those nets came with two hooks that had to be affixed (screwed) to the sides of the interior. If this is accurate, perhaps all you need is to do a lap around the "hardware" bins at Home Depot.
Post some pics, let's see.
You can get the hardware for it. Here’s a tip though, found this strategy here, use the Tonneau cover lever for the loop and the hooks hook into the metal hook in the bottom (deisgned for tie downs). I will see if I can locate a picture. I am sure there was a thread on this DIY. This way eliminates the need to bore holes and install the hooks. Otherwise you can easily find similar hardware that you can use. I do not think you can get the Lexus hardware without the net.
Here's what I meant...
