TPMS sign is on after a new set of tires, what to do?
Old 12-07-13, 01:39 PM
lvn098
lvn098's Avatar
Thanks for the info. I'll need to buy 5, rather replace all 5 instead of just the broken ones. They should also sell set of 5.
Old 12-07-13, 02:09 PM
RX330inFL
RX330inFL's Avatar
Yes, you are correct. Am going to guess you will have to add an additional single unit to your basket. With fewer vehicles having a full size spare it seems it is less important to sell a 5 pack though a seller should note the information to increase sales when the spare is included.
Any time you have tires replaced, those with TPMS should have the sensors inspected to determine the charge on the batteries and they should be replaced as a group as necessary at that time.
Old 12-08-13, 04:38 AM
lvn098
lvn098's Avatar
Where do you go to have new Sensors put in at a reasonable price? My mechanic said he'll do it for $40 each, totaling $200 for 5 tires. I think that's too much.
Someone had said Walmart or Discount Tires might be a better place. I think $10-$20 each is more reasonable.
Old 12-09-13, 01:20 AM
dcdyd
dcdyd's Avatar
Do you really need the sensor? If you are hit by a nail on the road, sensor won't be able to prevent it from happening. Just check the tire pressure once every week you are good to go.
Note that when the temperature is lower in the winter the air pressure goes down. So you need to put more air in the tire in the winter and get some out in the summer.
Old 12-09-13, 05:45 AM
ALSHUBCAPS
ALSHUBCAPS's Avatar
expected battery life on tpms is 5-7 years so it is possible some of the batteries are dead or dying. if you had the tpms tested & they didn't register on the shops tool then they need to be replaced. as for dead battery or sears damaging them, you can find out when the tire is dismounted. as for $200 ea....... after you shoot the guy in the face for that quote, shop around, we sell your tpms for $44 ea. & find a real tire shop to do the install unless sears is willing to give you a deal since they just did the install & can do the reset.
Old 12-09-13, 06:48 AM
jgr7
jgr7's Avatar
Sewell sells TPM for $59.21 each, Says batt life is 10 years.
Old 12-09-13, 02:21 PM
kickin8
2IS/2RX/4RX
kickin8's Avatar
interstingly enough.....Mrs' RX TPMS light was on when I replied on Friday....checked pressures of all 5 tires - no leaks.....resetted the light and call it a day....LOL
Old 12-09-13, 02:24 PM
RX3302004
RX3302004's Avatar
Discount charged $100 each the last time I looked.
Old 12-09-13, 09:21 PM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Received 3,849 Likes on 2,334 Posts
Here's what Lexus trains their techs:
Originally Posted by Lexus TTC
Tire Pressure Sensors The Tire Pressure Sensor is integrated in the air valve and operates with a lithium battery, which lasts approximately 10 years. If the battery voltage drops, the Tire Pressure Monitor Receiver stores the DTC in its memory. If the voltage drops even further and the sensor stops working, the Tire Pressure Monitor Receiver stores the DTC in memory and illuminates the Tire Pressure Warning Light to alert the driver.
mickjh
ES - 6th Gen (2013-2018)
16
12-30-19 04:22 PM
craig72
ES - 5th Gen (2007-2012)
30
02-28-18 08:44 AM
UnderCover
02-01-16 04:26 AM
sambb
01-25-16 07:48 AM
mikegs2006
11-16-11 08:28 PM
Quick Reply: TPMS sign is on after a new set of tires, what to do?
