Radiator not venting to reservoir
Old 06-16-13, 08:28 AM
shikbas
shikbas's Avatar
Default Radiator not venting to reservoir
Hello after a long trip i was checking the fluids of rx 330 I notised that the white plastic container for the coolant is low on coolant then i did a mouth pressure test at the radiator of courese cleanly and after removing the cap and the container cover not possible to blow through. I know this has to be open. I checked that before and it was open. Any suggestions please. Thank you
There was no overheating at all
Old 06-16-13, 06:11 PM
shikbas
shikbas's Avatar
Problem solved
Old 06-16-13, 06:14 PM
HtownBlue
HtownBlue's Avatar
Care to share what the "problem" was.
Part of the value of this place is to leave feedback and input for others. A simple problem solved helps no one if they are to ever encounter this issue.
Not trying to be rude, just stating that feedback and follow up should always be left.
Old 06-17-13, 05:38 AM
shikbas
shikbas's Avatar
Fair enouph,I removed the pipe at the buttom of the overflow tank and found a plug of some pasty material cleaned it out with a wire ,flushed the tank and cleaned the pipe itself,every thing checked well ,reconnect ,added fluid,and done
veronchu
08-23-17 01:48 PM
Sleepr
GS - 1st Gen (1993-1997)
10-06-09 07:43 AM
PDXdwild
Performance & Maintenance
12
05-21-09 01:44 PM
kendogger2002
Maintenance
12-10-02 06:38 AM
Quick Reply: Radiator not venting to reservoir
