Disable Steering Lock
Old 04-20-12, 04:58 PM
F14AV8R
F14AV8R's Avatar
Default Disable Steering Lock
Hi Everyone,
I tow my 2004 RX330 behind my motorhome with all four wheels on the ground. I currently have to have the key on to keep the steering wheel unlocked. The problem with that is the battery runs down sometimes. I've tried feeding power from the motorhome but I still end up with a dead battery now and then. I'm tired of troubleshooting the electrical system to determine why.
So, I want to disable the steering wheel lock so the steering will be free WITHOUT a key in the ignition. I'd appreciate any help / advice you might have before I start tearing the steering apart.
For example, does anybody have an exploded diagram of the steering wheel lock mechanism?
Any advice on how best to disable the lock?
Are there any interlocks or other sneaky immobilizer things I need to worry about?
Thanks in advance for the help.
PS: I'll try to head off the concerned posts about towing. I use a REMCO lube pump powered by the motorhome electrical system that keeps the RX transmission happy while towing.
Bandura (09-09-23)
Old 11-21-13, 03:48 AM
asif00
asif00's Avatar
hi can any one help ... i have the same situation with the same suv...
Old 11-25-13, 05:32 AM
arbrnrngr
10th Gear
arbrnrngr's Avatar
Just to ask the obvious (and possibly dumb question) - What about unlocking steering, putting car in neutral and put a properly sized on-off switch on the battery, effectively disconnecting it when towing?
I'm also assuming you have a separate lighting array for the back of the RX (e.g. brakes, turn signals, running lights).
Just a thought ...
scatton
RX - 3rd Gen (2010-2015)
11-19-17 04:13 PM
Jeepdude
06-13-16 04:42 PM
andrew0406
10-30-15 04:25 PM
Dx3
SC- 1st Gen (1992-2000)
24
04-04-10 07:37 PM
Quick Reply: Disable Steering Lock
