Need help to resolve Cold Start Problem
Old 10-29-14, 10:30 AM
phuatw
phuatw's Avatar
Default Need help to resolve Cold Start Problem
My Lexus Rx350 (2007) having problem starting the car when the engine is cold or switch
off more than 1-2 hours. I need to crank the car at least 2-3 times to get the engine run.
Once the engine run, i have no problem restarting the car with a single crack.
Regards Henry
Old 10-29-14, 10:47 AM
kickin8
2IS/2RX/4RX
kickin8's Avatar
Have you replaced your battery?
Old 10-30-14, 10:24 AM
LSBen
LSBen's Avatar
Maybe your fuel injectors are clogged. Try a bottle of fuel injector or fuel system cleaner. It can't hurt.
Old 11-02-14, 04:37 PM
mmarshall's Avatar
Welcome to CL.
Could be any one of a number of things. Weak fuel pump, clogged injectors, coolant-temperature sensor, throttle-position sensor, or others. Is the CHECK ENGINE light on?...that could signal a bad sensor, or a series of tests that need to be for that computer-code.
Old 11-02-14, 05:00 PM
HtownBlue
HtownBlue's Avatar
Without seeing the fuel trim numbers just after cold start, it will be hard to diagnose. It's normal for the engine to have to crank over a slight bit extra after sitting for a while if you immediately turn key and try and start. Fuel pressure takes about a 1/4 second to get up to normal after sitting a while. That said, you could have a lot of things causing this. Hard to say without looking at the live data when cranking up.
Old 11-04-14, 03:22 AM
tomit
tomit's Avatar
Agreed - do it each oil change.
redsue97
RX - 1st Gen (1999-2003)
02-16-18 06:44 PM
Dietz1968
12-16-16 02:58 PM
Bankswood
Performance & Maintenance
17
01-22-13 06:32 PM
YOX
01-21-10 05:27 PM
Quick Reply: Need help to resolve Cold Start Problem
