Old 12-16-14, 12:57 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Lexus IS Engine and Powertrain Guides
Print Wikipost
whining sound on deceleration from ~45 mph. definitive answer?
Old 05-31-15, 01:46 PM
Tzakiel
Tzakiel's Avatar
Originally Posted by LazarusLng
Shift into neutral when you are coasting. I bet the noise goes away.
Yes it does immediately. - Edit: actually I tested more today and it makes the same sound in neutral as well. I am probably derailing the thread as I have mentioned I have a gs350, but anyway there is my result. Not sure how to get the dealer to actually fix it though.
Old 05-31-15, 04:59 PM
LazarusLng
LazarusLng's Avatar
Originally Posted by Tzakiel
Yes it does immediately. I am probably derailing the thread as I have mentioned I have a gs350, but anyway there is my result. Not sure how to get the dealer to actually fix it though.
Not sure if there is anything for them to fix. How does the transmission act otherwise?
Old 06-01-15, 07:52 PM
Tzakiel
Tzakiel's Avatar
I tested more today and actually the sound doesn't change at all when shifting to neutral. Still there. Does that tell us anything?
Old 06-02-15, 07:41 AM
NateJG
NateJG's Avatar
It means that gearing just moved to a lower priority in the list of likely candidates - and since, IIRC, your whine is tied to speed, and my experience with "whine" and "bearing" is usually in the same sentence with "gear", and since gear is no longer my top concern - I'd widen the area of search.
Have you considered purchasing an extension cord and sticking the microphone from your cell phone in areas of suspect?
Have you conclusively ruled out tires? (I would have bet a week's pay that a front wheel bearing was about to self-destruct based upon a loud growl at mid-to-low speeds. It disappeared the instant new winter tires went on; and resumed the instant the summer tires went back on. I was humbled by that mis-diagnosis.)
Old 06-02-15, 09:38 AM
Tzakiel
Tzakiel's Avatar
Hm... I looked up wheel bearing noise and it is described as a helicopter or playing card shuffling noise... mine's nothing like that. More like blowing over a bottle opening - that kind of whistle or whine sound.
Old 06-02-15, 10:36 AM
NateJG
NateJG's Avatar
Two of the benefits of aging into Senior Citizenship are: 1) you can likely afford a garage with a floor clean enough to pinpoint oil leaks in failing components; and 2) Tinitis and short-lived hearing aid batteries mask noises that evaded diagnosis when you were younger.
A good working knowledge of mechanical things is a curse; while
A good audio system is a blessing.
Old 01-26-17, 10:36 AM
Itsmejoka
Itsmejoka's Avatar
Default ?
did This issue ever get resolved ?
riknchar
05-03-16 03:48 PM
abayacal
02-11-15 10:04 PM
muggie
10-24-12 07:43 PM
GTESCTHREE
SC- 1st Gen (1992-2000)
03-26-11 01:46 PM
shabbyblue
01-06-09 02:55 PM
Quick Reply: whining sound on deceleration from ~45 mph. definitive answer?
